September 3, 2012, 11:34 |
Particle transport
Vishal Nandigana
Rep Power: 18 |
Dear Foamers,
I would like to solve the following Newton's law of motion: dp/dt = F(x), where p is the position of the particle, and x corresponds to the current p value. I have the distribution of F with respect to x. In other words, in algebraic sense, p_new = p_old + (delta_t)*F(p_old). My query is how to calculate F(p_old) at every time step. Please let me know. Regards Vishal |
September 4, 2012, 05:12 |
Julien
Hi vishal
your question is quite strange here, in an OpenFOAM forum. OpenFOAM is a computing tool which works on FIELDS. A field is a concept of "something" which can vary respect to time and 3D space. Let say function f(x,y,z,t). This "something" can be a lot of different things: pressure, velocity, temperature, density, strain, stress, phase,... Mathematically, these "things" are described in terms of scalars, vectors, tensors. The power of OpenFOAM relies on a formal language which is able to solve for partial derivative equations. You can download here some documentation: www.openfoam.org/docs/ Mathematically, your problem seems to be "simply" a problem of integration. GNU Octave should be better tool for you. Physically, I think you are mysunderstanding: in this equation, p is not the position but the momentum, saying a product of a mass m and a velocity v. Velocity is the derivative of the position x. |
September 4, 2012, 10:25 |
Vishal Nandigana
Rep Power: 18 |
Hi Julien,
Thanks for the reply. Well, the equation I wanted to solve is the Langevin/Brownian dynamics with White noise, and neglecting the acceleration term in it. I wanted to couple this equation into Poisson - Nernst Planck equation which I have developed in OpenFOAM. However, before incorporating the noise and complicating it I wanted to know, if it is possible to calculate the variable f at a particular position, in the following equation. dp/dt = A*f(x=p_old) You are right, it is a momentum equation, however, I neglect the acceleration and consider a position dependent force. Please let me know, how to incorporate this equation in OF or in general how to solve for a Langevin equation. Thanks Regards Vishal |
September 4, 2012, 15:10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Vishal: If I understand you correctly, I think you can look into the Lagrangian capabilities that OpenFOAM has: http://www.openfoam.com/features/lagrangian.php Another possibility would be to look into the tutorial "mesh/moveDynamicMesh/simpleHarmonicMotion", which I think it solves a weight box hanging on elastics or cables... Best regards, Bruno edit: I've moved this thread to the programming section, which is where this fits the best...
September 4, 2012, 15:52 |
Vishal Nandigana
Rep Power: 18 |
Thanks Bruno. I would read it and would contact you.
Regards Vishal |
January 26, 2013, 22:02 |
Vishal Nandigana
Rep Power: 18 |
Hi Bruno,
I want to simulate a chain of particles, whose interaction potential is known (say a nonlinear spring potential + Lennard-Jones potential). I want to study the dynamics of this chain using Lagrangian approach. However, I would like to know if it is possible to add a noise force with a Gaussian distribution in the Newton's equation. Also, is it possible to implement Lennard-Jones type potential in OF while solving the dynamics. Kindly let me know where I could find some tutorials for such cases. Thanks a lot for the help Regards Vishal |
January 27, 2013, 06:04 |
Bruno Santos
Rep Power: 128 |
Hi Vishal,
I don't know of any tutorials that have all of those characteristics, but here's a list of links that can help you start to track down this kind of information:
Bruno
February 6, 2013, 10:16 |
Vishal Nandigana
Rep Power: 18 |
Hi Bruno,
I would like to solve the following equation fvm::laplacian(eps_r,Phi) == -alpha * Z1*C1-alpha*Z2*C2 where eps_r is spatially varying. I wrote the code to solve this problem when eps_r(x) at time t=0 is specified. However I would like to know if it is possible to define a function in OpenFOAM where eps_r is a function of time and space. Once this is defined, I want to read this variable at every time instant and solve the above governing equation. Please let me know. Thanks Regards Vishal |
Particle Transport & Termination Control with User FORTRAN | Julian K. | CFX | 3 | January 12, 2012 09:48 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
particle transport model | Fabiana | CFX | 0 | January 10, 2006 15:00 |
Particle transport model! | Danney | CFX | 2 | April 15, 2003 02:24 |
convergence in particle transport model | Jose Tinoco | CFX | 0 | March 3, 2003 03:10 |
