-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   new thermodynamic model (http://www.cfd-online.com/Forums/openfoam-programming-development/106745-new-thermodynamic-model.html)
Tobi September 6, 2012 18:30
Hi all,
i am working on a new thermodynamic model based on the flamelet solver of alberto cuoci.
I copied the thermodynamic src code into a new folder, called SLFMThermo
and renamed everything in the code to SLFM...
Okay ... after that I compiled the basicThermo and the SLFMThermo and everything worked fine.
After that I removed everything and build the alberto thermodynamicm model again and it worked :)
Now I added my model to the Make/files file and compiled again.
As I get to the SLFMThermo I ll get the following output:
SLFMThermo/SLFMThermo.C:32: error: redefinition of ‘Foam::SLFMThermo<MixtureType>::SLFMThermo(const Foam::fvMesh&)’
SLFMThermo/SLFMThermo.C:32: error: ‘Foam::SLFMThermo<MixtureType>::SLFMThermo(const Foam::fvMesh&)’ previously declared here
SLFMThermo/SLFMThermo.C:298: error: redefinition of ‘Foam::SLFMThermo<MixtureType>::~SLFMThermo()’
SLFMThermo/SLFMThermo.C:298: error: ‘virtual Foam::SLFMThermo<MixtureType>::~SLFMThermo()’ previously declared here
SLFMThermo/SLFMThermo.C:305: error: redefinition of ‘void Foam::SLFMThermo<MixtureType>::calculate()’
Why do I get redifinition error ? SLFMThermo is just declared in the SLFMThermo dict. The other thermodynamic is called hPdfThermo ?
Can someone give me an advice?
Tobi
Tobi September 7, 2012 03:55
Hi all,
today I had a look at the thermodynamic model hRho and hsRho and its the same like I have.
Well I simplyfied my c++ code so that there is just the constructor and deconstructor in the header and source files. I get the same error:
SLFMThermo/SLFMThermo.C:59: error: redefinition of ‘Foam::SLFMThermo<MixtureType>::~SLFMThermo()’
SLFMThermo/SLFMThermo.C:59: error: ‘virtual Foam::SLFMThermo<MixtureType>::~SLFMThermo()’ previously declared here
My source file is:
#include "SLFMThermo.H"
#include "fixedValueFvPatchFields.H"
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
template<class MixtureType>
Foam::SLFMThermo<MixtureType>::SLFMThermo(const fvMesh& mesh)
    basicFThermo(mesh),
    MixtureType(*this, mesh),
    h_laminar_
        IOobject
            "h",
            mesh.time().timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionSet(0, 2, -2, 0, 0),
        hBoundaryTypes()
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
and my header file is:
#ifndef SLFMThermo_H
#define SLFMThermo_H
#include "basicFThermo.H"
#include "basicMixture.H"
#include "OpenSMOKE_SLFM_NonAdiabaticFlamelet_Library.hpp"
namespace Foam
                        Class SLFMThermo Declaration
class SLFMThermo
    public basicFThermo,
    public MixtureType
private:
        volScalarField h_laminar_;
        OpenSMOKE_SLFM_NonAdiabaticFlamelet_Library    flamelets_library;
private:
        SLFMThermo(const SLFMThermo<MixtureType>&);
public:
    //- Runtime type information
    TypeName("SLFMThermo");
    // Constructors
    //- Construct from mesh
    SLFMThermo(const fvMesh&);
    //- Destructor
    virtual ~SLFMThermo();
} // End namespace Foam
#ifdef NoRepository
#  include "SLFMThermo.C"
#endif
#endif
I do not know why the output is "redefinition"? ?
Couse if I just compile my thermo model it works. with both - i get redifinitions :(
Tobi September 7, 2012 05:33
Hi all,
I fixed the problem.
I deleted all folders and did the same things again.
Now I can compile everything without any errors and the solvers are working :)
If the laminarFlameletSolver works good and the validation gives good results I ll share it with you!
Tobi
