Simple question about icoFoam
Old   September 13, 2012, 21:42
Default Simple question about icoFoam
Yuri Almeida
Yuri Almeida is on a distinguished road
Dear all,
The momentum equation in icoFoam.C (OF21) is the following:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
If I understood right, the equation would be:
d(U)/dt + div(rho*U*U) - laplacian((mu/rho)*U) = -grad(p) (1)
But the equation found in books is:
d(rho*U)/dt + div(rho*U*U) - laplacian(mu*U) = -grad(p) (2)
or, dividing by rho:
d(U)/dt + div(U*U) - laplacian((mu/rho)*U) = -(1/rho)*grad(p) (3)
My question is: Why are equation 2 and 3 different from 1? Probably they are not, but, where is "rho" in -fvc::grad(p) and why is it present in div(phi, U)??
Thx in advance!
Yuri Almeida is offline   Reply With Quote
Old   September 14, 2012, 03:51
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
in (1) you have rho in the convective term
Maybe that's because you misinterpreted phi. phi is the flux of a variable, rho does not come into it. So, (1) should read
d(U)/dt + div(U*U) - laplacian((mu/rho)*U) = -grad(p) (1.1)
If you now compare (1.1) with (3) the only difference is in p. If you check the dimensions of p in an icoFoam case (look at the file ./0/p) you will see, that with icoFoam the pressure does not have the dimension of a pressure (Force divided by area).
In an icoFoam case, the dimension of pressure is
dimensions [0 2 -2 0 0 0 0];
So, although in eq (1.1) and eq (3) the symbol p is used, the meaning of p is not the same in this equations.
In icoFoam p is a pressure that's been divided by rho.
GerhardHolzinger is offline   Reply With Quote
Old   September 14, 2012, 08:34
Yuri Almeida
Hi Gerhard,
Now I got it, I knew that the equation was right, but I didn't understand how. So, phi is flux, this makes sense, however, I saw that phi = rho*U from here:
http://www.openfoam.org/docs/user/fvSchemes.php
"The divSchemes sub-dictionary contains divergence terms. Let us discuss the syntax of the entry in reference to a typical convection term found in fluid dynamics div(rhoUU), which in OpenFOAM applications is commonly given the identifier div(phi,U), where phi refers to the flux phi = rhoU."
Thanks for the attention, Gerhard.
Old   September 14, 2012, 09:04
Gerhard Holzinger
I see, maybe that is the case for compressible solvers. In an incomressible case rho is eliminated.
Simple Beginner User Question on 'geometry' scottimus FLUENT 5 March 27, 2012 13:17
Simple Question - or not? Florian2 Main CFD Forum 10 November 17, 2011 16:48
Question about PISO in IcoFoam titio OpenFOAM Running, Solving & CFD 5 September 17, 2010 13:31
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 10:58
Simple icoFoam simulation gone wrong rieuk OpenFOAM Running, Solving & CFD 3 March 5, 2010 02:24
