Home > Forums > OpenFOAM Programming & Development
What does this Error mean?
Old   September 17, 2012, 08:22
Default What does this Error mean?
Christoph_84 is on a distinguished road
I programmed a Solver, witch works on one PC, now I want to compile the code on an other one and got this error:
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/StaubThermoDust_2D_Mix> wmake
 Making dependency list for source file StaubEx.C
 SOURCE=StaubEx.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/finiteVolume/cfdTools     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/StaubEx.o
 /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H: In Funktion »int main(int, char**)«:
 /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: Warnung: Variable »transonic« wird nicht verwendet
 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/finiteVolume/cfdTools     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/StaubEx.o -L/opt/openfoam171/lib/linux64GccDPOpt \
      -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -lfiniteVolume     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix
 Make/linux64GccDPOpt/StaubEx.o: In function `main':
 StaubEx.C:(.text+0x3bf8): undefined reference to `Foam::hCombustionThermo::New(Foam::fvMesh const&)'
 collect2: ld gab 1 als Ende-Status zurück
 make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix] Fehler 1
to test it i make a copy of rhoReactingFoam and try to compile this and got a similar error
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/rhoReactingFoam_test> wmake
 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel     -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude     -I/opt/openfoam171/src/thermophysicalModels/chemistryModel/lnInclude     -I/opt/openfoam171/src/ODE/lnInclude     -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/rhoReactingFoam.o -L/opt/openfoam171/lib/linux64GccDPOpt \
      -lbasicThermophysicalModels     -lspecie     -lcompressibleTurbulenceModel     -lcompressibleRASModels     -lcompressibleLESModels     -lfiniteVolume     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test
 Make/linux64GccDPOpt/rhoReactingFoam.o: In function `main':
 rhoReactingFoam.C:(.text+0x23a8): undefined reference to `Foam::rhoChemistryModel::New(Foam::fvMesh const&)'
 make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test] Fehler 1
What does this mean and how I can solve it?
Christoph
Christoph_84 is offline   Reply With Quote
Old   September 17, 2012, 09:17
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Christoph,
Are both machines using the same version of OpenFOAM?
Best regards,
Bruno
Old   September 17, 2012, 09:55
Yes, both 1.7.1, I have now solved the problem by recompiling OpenFoam. It seams that the computer wasn’t set up properly.
Christoph
Thread Tools
Trackbacks are On
