April 19, 2010, 17:41 |
Confusion face-addressing for surfaceField
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi all
I am confused with respect to the addressing of boundary face values for surfaceFields. Assume that the index "fLabelGlobal" is for a face on a boundary in terms of global indexing and "fLabelLocal" is targeting the same face, however in term of index locally on the boundary field. Then I can produce identical results with: mesh.Cf()[fLabelGlobal] and scalarField cf = mesh.Cf().boundaryField()[correctIndex]; cf[fLabelLocal]; However trying to do phi[fLabelGlobal] produces garbage whereas scalarField phiw = phi.boundaryField()[correctIndex]; phiw[fLabelLocal]; produces the correct result. Both mesh.Cf() and phi are surfaceFields, however they appear to behave differently, what am I doing wrong? By the way, I am working on cell level and need to target phi on all faces irrespectively of them being internal or boundary faces. I have made a hack to yield phi correctly, however it is painfully slow, thus any help is appreciated. Best regards, Niels |
April 20, 2010, 05:25 |
Stefan Herbert
Rep Power: 17 |
Hi Niels,
the only difference I see is that phi is a surfaceScalarField while mesh.Cf() is a surfaceVectorField. Might this be the problem? Maybe there is a special boundary treatment for surfaceScalarFields only. I'll keep on trying. Regards Stefan |
January 19, 2011, 16:03 |
Bill Rosemurgy
Rep Power: 17 |
Hi Niels,
Did you ever figure out the issue? I'm struggling with the same issue, trying to map faces on a boundaryField from a subMesh back to the full mesh. I have an fvMeshSubset called evaluationMesh and it shares common faces on patch 3 with the full mesh. Code:
volVectorField u(IOobject("u", runTime.timeName(), evaluationMesh.subMesh(), IOobject::NO_READ, IOobject::AUTO_WRITE), evaluationMesh.subMesh(), Foam::vector(0,0,0)); patchi = 3; // This gives the correct mapping between patches const label& patchI = evaluationMesh.patchMap()[patchi]; // calcU returns a vectorField u.boundaryField()[patchi] = calcU(evaluationMesh.subMesh().C().boundaryField()[patchi]); // Map back to full field forAll(u.boundaryField()[patchi],facei) { // This is where the issue is becuase facei counts from 0 -> nFaces on patchi of boundaryField // when I need it to index in the global sense for the mapping to be correct const label& faceI = evaluationMesh.faceMap()[facei]; U.boundaryField()[patchI][faceI] == u.boundaryField()[patchi][facei]; } Any insight? Thanks! Last edited by brosemu; January 19, 2011 at 16:10. Reason: clarity |
January 20, 2011, 03:39 |
Rep Power: 37 |
Hi
As you do note, you merely need to get hold on the global face-count for facei, then you will get a global faceI which needs to be transformed into a local patch faceI. I have recently done something like that: Code:
const fvPatchList & patches = cMesh_.boundary(); const fvPatchList & gpatches = mesh_.boundary(); const label nInternalFacesGlobal = mesh_.nInternalFaces(); forAll ( patches, patchi ) { const fvPatch & curPatch = patches[patchi]; if ( curPatch.type() != "empty" ) { label start = curPatch.patch().start(); scalarField & gw = gammafC.boundaryField()[patchi]; forAll ( gw, facei ) { label gfacei = faceMap_[start + facei]; if ( gfacei >= nInternalFacesGlobal ) { label gpatchID = mesh_.boundaryMesh().whichPatch(gfacei); label gstart = gpatches[gpatchID].patch().start(); label lstart = gfacei - gstart; const scalarField & ggw = gammaf.boundaryField()[gpatchID]; gw[facei] = ggw[lstart]; } else { gw[facei] = gammaf[gfacei]; } } } } I hope this can help you overcome your problems. Best regards, Niels P.S. Note that you need to consider the directions of the patch normals when mapping phi. This is due to the definition of a surface normal vector pointing to the outside on a patch, however a face on the global mesh being turned into a patch face has not been constructed originally with this constraint, hence it might be pointing in the wrong direction as a patch face. |
January 20, 2011, 18:56 |
Bill Rosemurgy
Rep Power: 17 |
Hi Niels,
That fixed it! The two pieces of information I needed where that you can access the global starting index (of course you can!) and that the globalIndex = startIndex + localIndex (of course it does!). Thanks again. |
October 2, 2012, 16:40 |
addressing in surfacescalarfield
Rep Power: 14 |
Do you guys know how the elements of surfacescalarfield are addressed? for example which which position does phi[celli] exactly refer to?
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
