Home > Forums > OpenFOAM Programming & Development
Access cell properties
Old   September 26, 2012, 15:48
Default Access cell properties
Adam
Smed is on a distinguished road
Hoes does one access cell properties such as pressure and temperature? I can't seem to find this in the programmer's guide.
Smed is offline   Reply With Quote
Old   September 28, 2012, 03:06
Christian Lucas
Chris Lucas is on a distinguished road
have a look at src/thermophysicalModels/basic/psiThermo/hPsiThermo/hPsiThermo.C
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   September 28, 2012, 11:43
Adam
Thanks Christian. I'm using the sprayFoam solver, so I think in my case I use the SLGThermo.H. I'm still not sure how to use the thermo models, but I found that cell pressure and temperature variables are defined in createFields.H by the following line:
volScalarField& p = thermo.p();
When I run my code in gdb, I can print out this cell pressure while in the main loop using,
"print p[cellnumber]"
But when I enter the parcels.evolve() function, I'm no longer able to access the "p" variable. This is where I'm hoping to actually use the cell properties, so I'm not sure where to go from here.
Old   October 6, 2012, 07:38
Default oscillatingFixedValue
T.Matrix is on a distinguished road
Hello, everyone:
Recently, I read the source code about oscillatingFixedValue. It is a useful BCs, and provides a convenience for users. Because of a new in OpenFOAM, there are some questions I hard to understand for class oscillatingFixedValue.
1. For implementing of private member function currentScale(), there is a program statement as follow:
const scalar t= this->db().time().timeOutputValue(). I don't know what does the this->db() mean?
2. From within constructors function
template<class Type>
oscillatingFixedValueFvPatchField<Type>:scillati ngFixedValueFvPatchField
const oscillatingFixedValueFvPatchField<Type>& ptf,
const fvPatch& p,
const DimensionedField<Type, volMesh>& iF,
const fvPatchFieldMapper& mapper
what's the meaning of iF? We just need to set the value on BCs, why does it need this auxiliary parameter iF?
3. who can describe some details of Mapping functions?
thank you.
T.Matrix is offline   Reply With Quote
Thread Tools
Trackbacks are On
Access cell face center / cell vertices lichmaster OpenFOAM Programming & Development 7 May 31, 2014 02:31
Help Me, what's the Cell Above any given cell in 3D. gomane8 Main CFD Forum 3 September 11, 2011 21:29
Help Me, what's the Cell Above in 3D. gomane8 Main CFD Forum 0 September 10, 2011 19:09
how to access to the face value of VOF of each cell Wei Shao Fluent UDF and Scheme Programming 2 November 5, 2009 11:16
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 0 September 23, 2009 07:57
