-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   GGI for volumes / mesh mapping? (http://www.cfd-online.com/Forums/openfoam-programming-development/107478-ggi-volumes-mesh-mapping.html)
orca.blu September 28, 2012 05:21
Dear all,
I would like to solve some equations (CFD) on a mesh and other (neutron diffusion) on a different mesh.
The two meshes share the same physical space but are differently optimized.
Is there a way to pass the variables (e.g., T, q''', ecc. ) between the two non-conforming mesh?
i.e., to calculate the weighting factors from a generic cell on the mesh A to a generic cell on the mesh B, like GGI does for patches.
Matrix-level coupling between two equations living on different meshes would be great but is not strictly required since most of the strongly coupled equation would share the same mesh .
Can you suggest any presentation/paper/web-page/tutorial?
Thank you very much!
deepsterblue September 28, 2012 08:53
I did something very similar for volume fields. Take a look at my implementation:
https://github.com/smenon/dynamicTop...ervativeFields
You can get the methodology / citation here:
http://www.sciencedirect.com/science...45782511001666
orca.blu September 28, 2012 10:02
Thank you!
Good job, your work is quite wider than my needs :)
I was only looking for something very simple, similar to mapField to be performed at each time step.
I'll read your paper and I'll try to learn something new!
Thanks
Manuele
