Implement new turbulence model based on kOmegaSST
Like Tree2Likes
  • 2 Post By Tobi
Old   October 9, 2012, 12:47
Default Implement new turbulence model based on kOmegaSST
sh.d is on a distinguished road
Hi everybody
I want to create a turbulence model in openfoam. After the compiling the model, the following error has been showen in terminal:
Make/linux64Gcc64DPOpt/mykOmegaSST.o Error 1
Please guide me to sole it.
Thanks in advance
sh.d is offline   Reply With Quote
Old   October 9, 2012, 12:54
Hi
I have another question.
In which line in the constructor in the mykOmegaSST.C, I should write the following sentence:
Info << “Defining my own kOmegaSST model “ << endl ;
Thanks a lot.
Old   October 13, 2012, 05:02
Retired Super Moderator
Bruno Santos
Greetings sh.d and welcome to the forum!
I moved your questions to a new thread, because they had barely anything to do with that thread.
As for your question, here is some reading material:
You can also use Google (or some other search engine) and look with the following keywords:
openfoam adding new turbulence model
Best regards,
Bruno
Old   October 14, 2012, 07:57
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by sh.d View Post
Hi
Thanks a lot.
You do not have to make that!
Neeraj made a new turbulence model too, or better he changed the k-epsilon model and had some problems with it.
I helped him by build his turbulence model and uploaded it.
Have a look at the thread, download the turbulence-model and have a look at the code.
If you build your own turbulence model like I mentioned, you get the output message "mySSTModell" etc. automatically.
http://www.cfd-online.com/Forums/ope...tml#post386337
Tobi
wyldckat and neeraj like this.
Tobi is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 05:45
Nearwall treatment for the kOmegaSST turbulence model johnb OpenFOAM Running, Solving & CFD 3 January 22, 2009 02:52
How can run MRFSimpleFoam with KOmegaSST turbulence model waynezw0618 OpenFOAM Running, Solving & CFD 0 April 21, 2008 04:40
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 12:46
