Implementation of Implicit Source term in OpenFOAM
Like Tree2Likes
  • 2 Post By pradeepramesh
Old   August 14, 2014, 23:28
Default Implementation of Implicit Source term in OpenFOAM
Delstat
pradeepramesh is on a distinguished road
Dear All,
I am currently trying to solve linear and non-linear Poisson equation with implicit source terms in OpenFoam. I would like to request your feedback.
Case I : linear Poisson equation
Solve for : del^2(T) - T = 0
Source : S = -T
Implicit source: S = Su + Sp*T
Su = 0, Sp = -1
Open Foam: fvm::laplacian(T) == -fvm::Sp(Sp,T) + Su
I defined Sp and Su as "VolScalarField". I was successfully able to solve the case and compared it with the analytically results.
Case II: Non-linear Poisson equation
Solve for : del^2(T) - T^2 = 0
Source : S = -T^2
With taylor's series expansion:
S = To^2 + (- 2To)*T
Su = To^2, Sp = (- 2To)
I am facing errors to implement these sources terms.
How to mimic these equation in OpenFoam syntax?
How to define Su and Sp in terms of To.?
Please find the attached Snapshot for your reference.
Would be great to hear your feedback on Case II. Thank you very much and have a wonderful day.
Cheers,
Pradeep
Kummi and lpz456 like this.
pradeepramesh is offline   Reply With Quote
Old   August 18, 2014, 00:28
Cyp
Cyprien
Cyp is on a distinguished road
It would have been easier if you post the error message. The implementation is similar to your first case. I guess you should program Foam:ow(T0,2) for T0^2. Maybe your compilation error comes from here.
Another point you have to be careful is the dimension of T ! Indeed, despite the case where T is dimensionless, your equation is not correct (at least you should put an dimensionedScalar factor in front of your source term in order to be homogeneous).
Best,
Cyp
Cyp is offline   Reply With Quote
Old   August 18, 2014, 01:07
Delstat
Dear Cpy,
Thank you very much for your feedback and i highly appreciate that.
Could you please elaborate on the dimensionedScalar factor?
Case I: ----> fvm::laplacian(T)== -fvm::Sp(Sp,T) + Su
dimensionedScalar factor for source terms, you mean for Sp and Su???
Case II: ----> fvm::laplacian(T)== T*T*A
Where: A is a dummy object to make the operation compatible.
Thank you very much
Cheers,
Pradeep
Old   August 18, 2014, 01:10
Cyp
Cyprien
For both cases, I will declare A as :
dimensionedScalar A ("A", dimless/T.dimensions()/dimLength/dimLength, 1.0);
and then
fvm::laplacian(T) == -fvm::Sp(2*T0*A,T) + Foam::pow(T0,2)*A
Best,
Cyp
Old   August 18, 2014, 01:30
Delstat
Dear Cpy,
I have updated the new syntax and with the new dimension syntax,I am facing the incompatibility error for operation. Please find the attached snapshot for your reference.
Thank you very much.
Cheers,
Pradeep
Old   August 18, 2014, 01:40
Cyp
Cyprien
Indeed it is obvious (because of the laplacian..). I modified my previous post.
Old   August 18, 2014, 01:57
Delstat
It worked! Thank you very much Cpy
Old   May 20, 2016, 07:30
Alejandro
ancolli is on a distinguished road
Could you please explain how to modify code to solve a general nonlinear Poisson equation?
Step by Step if is it possible, because I do not fully understand
ancolli is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
Anisotropic, implicit momentum source term chris_j_meyer OpenFOAM Programming & Development 3 July 25, 2016 16:11
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Implicit source term and porousInterFoam Andrea_85 OpenFOAM Programming & Development 0 August 30, 2013 04:30
