Home > Forums > OpenFOAM Programming & Development
OpenFOAM from scratch to specific goal?
Old   October 11, 2012, 03:54
Default OpenFOAM from scratch to specific goal?
fantasy is on a distinguished road
Hi everyone,
Since I do not want to waste any time, I thought it would be good to ask some experienced people for a simple guideline of how I should approach a certain goal in a pretty short timespan. With short I'm talking about approximately 2 weeks (8 hours a day). Actually, I'm really interested in gaining advanced knowledge of OpenFOAM, but at this moment my time is too limited for that, so that will have to come later.
For now, my intention is to create a 3-dimensional mesh using a commercial software package and then use OpenFOAM to simulate the flow behavior and with that knowledge try to improve my mesh/the initial design. The solvers I am going to use (with or without altering them, I don't know about that yet) will be icoFoam and settlingFoam. At first I will simply simulate the problem with just a fluid and after that solid particles will be added. The hardest part of the problem will be to define the boundary conditions and match them with experiments that are going to be performed on a smaller scale as well.
So, getting to the point, what should I work on to achieve this? The 2 available weeks are mostly to get familiar with OpenFOAM, the relevant physics and simply how to use/modify the required solvers. Experiments and meshing will be done after that and then I will have some time to actually perform the simulations and improve my model.
Currently, I am in the 2nd year of my master, so I do have relevant knowledge, but it is all somewhat limited. I am familiar with the basics in different branches of fluid dynamics, finite element method and I also have some knowledge on the theory behind CFD (I know about discretization using CD, upwind schemes, TVD and such; explicit time integration schemes; relaxation, multigrid), but apart from writing some Matlab scripts, I have not really put any of this into practice yet. Also, I am completely illiterate when it comes to C++ (yet).
So, with all of the above in mind, what would be a good approach to get from A to Z? I have already completed the tutorials in the user- and programmer-guides, but other than learning some basic execution commands and finding out what is located where, these did not really give me the idea I learned a lot yet.
Thanks in advance!
fantasy is offline   Reply With Quote
Old   October 15, 2012, 10:40
Elvis
elvis will become famous soon enough
you might take a look at http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/ ..
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2011/
or go through OF workshop material
http://openfoam-extend.sourceforge.n...7_Program.html
http://openfoam-extend.sourceforge.n...m/training.htm
if you are illiterate to C++ you could try python if that is easier for you => http://pythonflu.wikidot.com/start although the installation is not that easy.
If you want to do optimization, do you want to use Dakota or adjoint?
elvis is offline   Reply With Quote
Thread Tools
Trackbacks are On
Specific OpenFOAM Code pbhuter OpenFOAM 13 June 30, 2012 19:06
modify specific heat ratio in OpenFOAM Gitesh P OpenFOAM Running, Solving & CFD 0 June 25, 2012 05:52
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x wyldckat OpenFOAM Bugs 18 October 21, 2010 05:51
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
