-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Implement new turbulence model based on kOmegaSST (http://www.cfd-online.com/Forums/openfoam-programming-development/108047-implement-new-turbulence-model-based-komegasst.html)
sh.d October 9, 2012 12:47
Hi everybody
I want to create a turbulence model in openfoam. After the compiling the model, the following error has been showen in terminal:
Make/linux64Gcc64DPOpt/mykOmegaSST.o Error 1
Please guide me to sole it.
Thanks in advance
sh.d October 9, 2012 12:54
Hi
I have another question.
In which line in the constructor in the mykOmegaSST.C, I should write the following sentence:
Info << “Defining my own kOmegaSST model “ << endl ;
Thanks a lot.
wyldckat October 13, 2012 05:02
Greetings sh.d and welcome to the forum!
I moved your questions to a new thread, because they had barely anything to do with that thread.
As for your question, here is some reading material:
You can also use Google (or some other search engine) and look with the following keywords:
openfoam adding new turbulence model
Best regards,
Bruno
Tobi October 14, 2012 07:57
Originally Posted by sh.d (Post 385777)
Hi
Thanks a lot.
You do not have to make that!
Neeraj made a new turbulence model too, or better he changed the k-epsilon model and had some problems with it.
I helped him by build his turbulence model and uploaded it.
Have a look at the thread, download the turbulence-model and have a look at the code.
If you build your own turbulence model like I mentioned, you get the output message "mySSTModell" etc. automatically.
http://www.cfd-online.com/Forums/ope...tml#post386337
Tobi
