Gravity & pressure handle in interFoam
Old   May 17, 2013, 08:04
Default Gravity & pressure handle in interFoam
Davide D.
dav.dap83 is on a distinguished road
Dear all,
I am currently trying to compile an interFoam version with kinematicCloud object inside.
However, there is an aspect I don't understand, namely how interFoam handles pressure and gravity. As far as I understand, in interFoam, gravity term does not compare in NS equations in UEqn.H, but a modified pressure p = p_rgh + rho*gh is introduced in createFields.H.
I performed a simple simulation of a laminar pipe single-phase flow with transverse gravitational fields, and compared the qualitative output with a similar simulation in pimpleFoam. A relevant difference appears, namely interFoam seems to ignore transverse gravitational field.
Do you know what is the reason of this different handling of gravity field? And what may cause the difference in the simulations' behaviors?
Thank you
dav.dap83 is offline   Reply With Quote
Old   May 22, 2013, 10:52
Kent Wardle
kwardle is on a distinguished road
You are correct in that interFoam uses a different formulation for pressure, but it also does define a field p with the 'normal' pressure and should work fine with kinematicCloud particle fields. And it should not ignore gravity. Have you verified in constant/g that gravity vector is defined as you intend? I ask because I forget this all the time and copy in a g file from a 2D run and find out a day later that my results are garbage because I forgot to correct the gravity vector direction.
-Kent
kwardle is offline   Reply With Quote
Old   May 22, 2013, 11:21
Davide D.
constant/g was ok, but boundary conditions for pressure were wrong. Thank you anyway
gravity, interfoam, navier-stokes, pimple, pressure
Pressure drag problem in porous media with interFoam skp OpenFOAM Running, Solving & CFD 8 May 27, 2015 08:10
Pipe Junction with interFoam Pressure Bounday Fails mgdenno OpenFOAM 8 April 5, 2013 09:39
interFoam and static pressure MatP OpenFOAM Running, Solving & CFD 1 July 15, 2012 11:35
interFoam: strange pressure with high fluid viscosity? ckroener OpenFOAM 3 April 7, 2010 12:51
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
