Energy equation
Old   August 14, 2015, 09:46
Default Energy equation
Shovan
shovan is on a distinguished road
May i know in which Openfoam solver will i get the following equation:
Why different solvers using navier stroke's equation have different momentum and energy equations? The navier stroke's equation should be same for all solvers right?
shovan is offline   Reply With Quote
Old   August 17, 2015, 08:46
chriss85 will become famous soon enough
Equations may differ because a different energy is used. For example some use inner energy while others use enthalpy. Also, some solvers are compressible while others are incompressible.
chriss85 is offline   Reply With Quote
Old   August 18, 2015, 01:58
Shovan
Thanks can you tell me in which solver of openfoam will i get the above mentioned energy equation.
regards
Shovan Kumar Sahu
Old   August 18, 2015, 02:20
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
reactingFoam can be the nearest choice, but without term #2 in RHS (sum h_j J_j)
But, if you will solve energy in enthalpies and assume Le number equal to 1, then term #2 in RHS will become compensated by enthalpy diffusion term
mkraposhin is offline   Reply With Quote
Old   August 18, 2015, 02:39
Shovan
Thank you all
modify a solver to account for energy equation. Yanci OpenFOAM Running, Solving & CFD 0 November 11, 2014 09:23
Energy equation issue zytra FLUENT 0 October 20, 2014 21:34
Need experience comment on cavitation combine energy equation!!! lehoanganh07 FLUENT 0 September 24, 2014 10:28
Energy equation in OpenFoam nwpukaka OpenFOAM Programming & Development 2 June 24, 2014 02:40
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
