-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   How to treat autoPtr<psiChemistryModel> ? (http://www.cfd-online.com/Forums/openfoam-programming-development/109791-how-treat-autoptr-psichemistrymodel.html)
Hanzo November 26, 2012 23:18
Hello together,
I have a question about a certain line of createFields.H of chemFoam:
http://foam.sourceforge.net/docs/cpp/a03249_source.html
00026    Info<< nl << "Reading thermophysicalProperties" << endl;
00027    autoPtr<psiChemistryModel> pChemistry(psiChemistryModel::New(mesh));
00028
00029    psiChemistryModel& chemistry = pChemistry();
00030    scalar dtChem = refCast<const psiChemistryModel>(chemistry).deltaTChem()[0];
What exactly is pChemistry? I see that psiChemistryModel is an abstract class and instances cannot be created using the standard constructor, right?
However, in line 29, what is pChemistry(); doing ?
Actually, what I want to do is: create a list of autoPtr<psiChemistryModel> and then perform line 29 for each entry of that list.
Here is my code which does not work:
// this part works
pChemistry.set
            i,
                fluidRegions[i]
            ).ptr()
// but this step does not work
psiChemistryModel& chemistry = (pChemistry[i])();
This results in the error:
fluid/createFluidFields.H:108: error: no match for call to (Foam::psiChemistryModel) ()
Hanzo November 28, 2012 05:53
Okay, found it. Just had to look at the implementation of
PtrList, List and psiChemistryModel :o
