December 11, 2012, 15:11 |
Accessing neighbor cells fields
Hello all,
I am trying to do an average of cells neighbors. For instance, if I want to get an average of Temperature in the internal field I can easily type Code:
sum(T.internalField())/mesh.nCells() What could be the function to do it just in cell neighbors? Could it be inside geometricField.C? Thanks! António |
December 11, 2012, 15:37 |
I think you need to do a bit more for that:
const labelList& neighbour = mesh.cellCells()[celli] scalar sum = scalar(0); forAll(neighbour,i) { sum += T[neighbour[i]]; } sum /= neighbour.size(); And loop over all the cells with that will give you an average of cell neighbours. You can find more of functions relating to the mesh information in primitiveMesh class. Duong |
December 11, 2012, 15:41 |
thanks a lot, I will give it a try!
Antonio |
May 13, 2015, 17:53 |
Vitor Geraldes
This a nice implementation, but, in parallel, it does not recognize neighbour cells if they are in subdomains different from the one of the central cell. Is there a simple implementation to address this problem?
January 20, 2018, 14:45 |
find neighbours in parallel
Thomas Flint
Rep Power: 10 |
I think if you use field.correctBoundaryConditions(); it will work OK. Where field is the new neighbour field you assign.
This works fine for me All the best |
April 30, 2021, 13:55 |
Daniel
Rep Power: 7 |
Hello everybody, for a new hybrid turbulence model I also need to calculate the mean of the current and neighboring cells. I am curious if there is a more efficient way doing the average instead of using a forAll loop?
May 3, 2021, 02:16 |
#7 | |
Mark Olesen
Rep Power: 40 |
Walk each internal face, get owner/neighbour locations and use that to add to the output (in two locations) and the neighbour count (again in two locations). After that walk the boundary faces (owner only). Finally, iterate across the boundary patches, adding in the off-processor information. Finalise your output field by preforming the averaging operation. Depending on what you need, interpolate cell vales to the faces and vol reconstruct from them could also be an interesting thing to look at. |
May 3, 2021, 03:14 |
#8 | |
Daniel
Rep Power: 7 |
volScalarField VTMav = fvc::surfaceSum(this->mesh().magSf() * fvc::interpolate(VTM(gradU))) / fvc::surfaceSum(this->mesh().magSf()); |
Time averaged fields on a defined time range | Yann | OpenFOAM Post-Processing | 8 | August 7, 2019 04:46 |
Accessing fields and dictionaries from within a BC implementation | alberto | OpenFOAM Running, Solving & CFD | 12 | December 6, 2011 09:30 |
Missing fields in reconstructPar | flowris | OpenFOAM | 1 | July 9, 2010 02:48 |
domainIntegrate, dieselFoam and Lagrangian Fields | mturcios777 | OpenFOAM | 0 | May 14, 2010 15:16 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
