icoFoam with multiRegion and passive scalar transport
Old   December 20, 2012, 10:44
Default icoFoam with multiRegion and passive scalar transport
Martin
RugbyGandalf is on a distinguished road
Dear FoamCommunity,
i try to build a solver, which allows me to simulate multiRegions with passive scalartransport from fluid to solid and back, for a nonNewtonian fluid.
I took pieces from chtMultiRegionFoam.C and nonNewtonianIcoFoam.C as well as some from scalarTransportFoam.
At the moment i am facing several problems. The actual one: i cannot compile the solver without any warnings/errors.
For instance: i can't figure out, why "fluid" is not defined, respectively where to define it.
I will upload the code of the .C file and the error-message from terminal as well.
Hopefully someone can help me.
Regards,
Martin
SOURCE=CDTnonNewtonianIcoFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -Ifluid -Isolid -Iinclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam211/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam211/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam211/src/thermophysicalModels/basicSolidThermo/lnInclude -I/opt/openfoam211/src/turbulenceModels/compressible/turbulenceModel/lnInclude  -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/CDTnonNewtonianIcoFoam.o
CDTnonNewtonianIcoFoam.C: In function ‘int main(int, char**)’:
CDTnonNewtonianIcoFoam.C:93: error: ‘fluid’ was not declared in this scope
CDTnonNewtonianIcoFoam.C:118: error: ‘pRefCell’ was not declared in this scope
CDTnonNewtonianIcoFoam.C:118: error: ‘pRefValue’ was not declared in this scope
In file included from CDTnonNewtonianIcoFoam.C:127:
/opt/openfoam211/src/finiteVolume/lnInclude/continuityErrs.H:40: error: no match for ‘operator+=’ in ‘cumulativeContErr += globalContErr’
CDTnonNewtonianIcoFoam.C:136: error: no matching function for call to ‘laplacian(const int&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)’
In file included from CDTnonNewtonianIcoFoam.C:149:
solid/lookupSolidDiffCoeff.H:2: error: ‘diffCoeffSolid’ was not declared in this scope
solid/lookupSolidDiffCoeff.H:11: error: ‘subDict’ was not declared in this scope
CDTnonNewtonianIcoFoam.C:154: error: ‘diffCoeff’ was not declared in this scope
solid/readSolidMultiRegionPIMPLEControls.H:3: warning: unused variable ‘nNonOrthCorr’
CDTnonNewtonianIcoFoam.C:76: warning: unused variable ‘finalIter’
/opt/openfoam211/src/finiteVolume/lnInclude/readTimeControls.H:32: warning: unused variable ‘adjustTimeStep’
/opt/openfoam211/src/finiteVolume/lnInclude/readTimeControls.H:35: warning: unused variable ‘maxCo’
/opt/openfoam211/src/finiteVolume/lnInclude/readTimeControls.H:38: warning: unused variable ‘maxDeltaT’
solid/readSolidTimeControls.H:32: warning: unused variable ‘maxDi’
make: *** [Make/linux64GccDPOpt/CDTnonNewtonianIcoFoam.o] Fehler 1
RugbyGandalf is offline   Reply With Quote
Old   January 2, 2013, 02:41
Ivo
Ivooo is on a distinguished road
Did you check the topic about chtIcoMultiRegionFoam? It can be found here [1], you might need to adjust it somewhat to fit your needs, but the basic framework is already there, it seems.
[1] http://www.cfd-online.com/Forums/ope...egionfoam.html
Ivooo is offline   Reply With Quote
