-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   A realy easy variable - problem (http://www.cfd-online.com/Forums/openfoam-programming-development/111351-realy-easy-variable-problem.html)
wernsen January 4, 2013 09:41
Hey guys,
I am going crazy. Here the code:
forAll(pSampledPlaneList, pI)
      pSampledPlaneList[pI]().update();
      fileName fname("plane_" + word(pI) + ".obj");
      pSampledPlaneList[pI]().write(fname);
I am a having planeList and I want to write them down. It works but there is a problem with the file name. The output looks like this: plane_?.obj
I think there is a problem with the variable type but I cannot solve it.
Thanks for any hint...
martin
l_r_mcglashan January 4, 2013 12:36
fileName fname("plane_" + name(pI) + ".obj");
wernsen January 7, 2013 11:43
thanks alot it works. But can you tell me how can I find out this the next time by my own? Just a few hints would be nice.
l_r_mcglashan January 7, 2013 14:25
Not sure, I just know it, but I often use grep to try and find out if there's already something similar to what I want to do around. You could have done the following search:
grep -e "fileName.*(*.obj" -R .
and one of the hits gives:
fileName cutsFile("hexCellLooper_" + name(cellI) + ".obj");
