Advice on BC implementation
Old   May 2, 2019, 11:48
Default Advice on BC implementation
rando_foamer is on a distinguished road
EDIT - in true rubber duck style, I thought of a way to do this immediately after hitting post!
I plan to modify the mixed BC code to change the way the updateCoeffs operation works.
Hi all,
I'm hoping someone can offer me some advice on how to implement the following mixed boundary condition in code (it's based on a chemical reaction rate occurring at a surface):
(DT/delta)*(C_P - C_b) = k * (C_b)^a
Here, the left hand side is simply a diffusive flux term, where DT is a diffusion coefficient, 1/delta is the patch deltaCoeffs, C_P is the concentration field of the current cell, C_b is the concentration of the boundary, k is a rate constant, and a is some arbitrary real value (positive or negative).
I can easily work out the answer for a=1, as the problem reduces to:
C_b = ( (DT/delta) / (k + DT/delta) )*C_P
And so, in typical mixed fashion, we can set:
refValue=0.0;
refGradient=0.0;
valueFraction=1-( (DT/delta) / (k + DT/delta) );
I've compared my coded BC for a=1 against a separate finite difference solution in Mathematica and they agree.
For a != 1, I'm completely stumped! C_b will end up being some strange polynomial in C_P and I have no idea how I should implement that in my code.
Any advice would be greatly appreciated. I'm assuming no such BC already exists in OF (at least, I can't find one that seems to be equivalent).
rando_foamer is offline   Reply With Quote
Radiation Models in General and the P1 implementation Tobi OpenFOAM Running, Solving & CFD 8 September 21, 2021 05:59
Issues in FGM combustion model implementation Lisandro Maders OpenFOAM Programming & Development 15 April 22, 2020 19:18
a little confused with the implementation of compressibleInterFoam su_junwei OpenFOAM Running, Solving & CFD 2 May 7, 2014 17:33
Implementation issues of fvSchemes / laplacianScheme, in particular gaussLaplacianSch thomek OpenFOAM Programming & Development 0 October 18, 2010 05:10
Please explain the implementation of species transport Eqn in reactingFoam kallipygian OpenFOAM Running, Solving & CFD 0 October 13, 2008 07:29
