-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Overwriting dictionary from BC (http://www.cfd-online.com/Forums/openfoam-programming-development/111832-overwriting-dictionary-bc.html)
Phicau January 16, 2013 08:31
Dear all,
I am creating a custom BC that has to read a dictionary, and after some calculations, write back some new values. My dictionary is initially located in ./constant/ folder, so it is accessed easily:
    IOdictionary flowDict
        IOobject
            flowDict_,
            this->db().time().constant(),
            this->db(),
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
Later on the code I try to write a new value:
        flowDict.set("allCheckAlpha", true);
        flowDict.Foam::regIOobject::write();
Everything works fine, but if I run my code in parallel, this dictionary gets written within ./processor*/constant/ . Then, if I restart the simulation, it is read by default from this last location.
It would be very convenient for me not to have hundreds of flowDicts scattered around in the ./processor*/constant/ folders, but just one copy in the main constant folder.
Any clues on how to fix this issue?
Thanks!
Pablo
JimKnopf January 25, 2013 05:24
Afaik you could just reconstruct the constant directorie by using
reconstructPar -constant
Best regards
Jim
