-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   where can I find functions definition in OF? (http://www.cfd-online.com/Forums/openfoam-programming-development/112184-where-can-i-find-functions-definition.html)
asoltoon January 23, 2013 09:57
Hello guys,
I wanna see some function definitions in KEpsilon.C, but I don't know where it is. I'v also searched in the OpenFoam.org 's C++ source guide but it was not useful.
I would be grateful if anybody could help me.
Thanks in advance.
Hisham January 23, 2013 10:12
Hello Ali
What do you mean by definition: the code or some explanation?
Is there a specific function that you are searching for?
Best regards,
Hisham
asoltoon January 23, 2013 11:14
Hello Hisham,
I mean the code implementation. There is lots of functions I would like to see their code, but for instance how I could find the DkEff() implementation. The function is used in KEpsilon.C.
Thanks
Hisham January 23, 2013 14:05
Originally Posted by asoltoon (Post 403583)
Hello Hisham,
Thanks
You just press on any link that says:
Definition at line 185 of file kEpsilon.C.
the kEpsilon.C link will take you to:
http://foam.sourceforge.net/docs/cpp/a08551_source.html
asoltoon January 23, 2013 15:00
But line 185 of the link that you mentioned doesn't point to the implementation of the DkEff() function. This function is declared at line 253 of kEpsilon.C & its implementation should be in another class I think. and when I click on the function colored in blue (at line 253), the opened page doesn't show me the function's code.
Thanks for your reply man ;)
mm.abdollahzadeh January 23, 2013 15:43
Hi
you could find the definition in
Definition at line 129 of file kEpsilon.H.
Cheers
mahdi
Hisham January 23, 2013 16:55
@ mahdi .. thanks
@ all: Sorry .. I just meant to tell you that the file is accessible from such lines that says definition at line ....
I hope this wasn't confusing ... :confused:
You can also find the function in your computer by going to the source code directory and typing:
grep -iIr "DkEff" .
and don't forget the "."
and then use Ctrl+f to search for the function inside the file after you open it with your text editor
Hisham
