October 13, 2009, 12:49 |
simpleFoam with energy equation
Sebastian Gatzka
Rep Power: 20 |
Hello world.
I'm dealing with a case in which Navier-Stokes and energy equation can be solved one after the other. I have little experience in manipulating solvers, but I think it's possible to alter the simpleFoam solver for such a case. So where do I put the energy equation? As I want to compute temperature after successfully converged Navier-Stokes-Equation I have thought about opening another time-loop and solving the energy equation there. Something like this: Code:
Info<< "\nStarting time loop\n" << endl; for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readSIMPLEControls.H" # include "initConvergenceCheck.H" p.storePrevIter(); // Pressure-velocity SIMPLE corrector { # include "UEqn.H" # include "pEqn.H" } turbulence->correct(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; # include "convergenceCheck.H" } #include 'TEqn.H' Info<< "End\n" << endl; return(0); Thanks for your ideas. See you. Sebastian
Schrödingers wife: "What did you do to the cat? It's half dead!" |
October 14, 2009, 02:57 |
Markus Rehm
Rep Power: 17 |
Hi Sebastian,
have a look at buoyantSimpleFoam. Regards, Markus. |
October 19, 2009, 14:04 |
#3 | |
Sebastian Gatzka
Rep Power: 20 |
So I will put the energy equation inside it too? Code:
{ # include "UEqn.H" # include "pEqn.H" # include "TEqn.H" }
November 20, 2009, 14:21 |
Sebastian Gatzka
Rep Power: 20 |
It took some time before I got back to this construction site:
Do you think buoyantSimpleFoam for itself (without chaning anything) will be the right choice for a simple convective heat transfer problem?
November 23, 2009, 02:31 |
Markus Rehm
Rep Power: 17 |
It worked well for me. But you can take out the buoyancy term as well.
Markus |
January 25, 2013, 15:05 |
TEqn.H
Suranga Dharmarathne
Rep Power: 15 |
Hi Markus and Sebastian,
Why can't we put the TEqn.H out side the SIMPLE loop. I think we need to calculate temperature field after we got corrected velocity field. Is my idea right or wrong? And since simpleFoam calculates turbulent flows I put my Teqn.H as, { volScalarField kappaEff ( "kappaEff", turbulence->nu()/Pr + turbulence->nut()/Prt ); fvScalarMatrix TEqn ( //fvm::ddt(T) fvm::div(phi, T) - fvm::laplacian(kappaEff, T) ); TEqn.relax(); TEqn.solve(); //rhok = 1.0 - beta*(T - TRef); } Please correct me if I am wrong. My temperature value fluctuates a lot whenever I used it out side the SIMPLE loop. But in pisoFoam I put it in outside the PISO loop and worked really good. Please advice me. Best regards, Suranga. |
January 26, 2013, 06:42 |
Hisham Elsafti
Rep Power: 17 |
Hi Suranga
I think the (rather old) discussion here was about the time loop not the Simple/pimple loop. Naturally one needs to keep the algorithm for the Navier-Stokes equations intact. You can add whatever equation outside the algorithm to let it resole the pressure-velocity coupling in peace. Of course all equations should be inside the time loop unless you need to solve an equation once. Hisham |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
question about energy equation | zhou | FLUENT | 0 | February 23, 2004 23:55 |
