-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Boundary condition setting for adding gravity in simpleFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/112945-boundary-condition-setting-adding-gravity-simplefoam.html)
norkistar February 8, 2013 07:51
Hi Foamers,
I am just starting simulation water flow in a horizontal circular pipe. Without adding gravity, it works well. With adding gravity, it can't converge. The result diverse and become unbelievable. I think problem might due to the boundary condition setting for p. I will list the step that I did for adding the gravity. Your kindly attention would be much appreciated.
1 I add g in the createFields.H as follows
Info<< "Reading g\n" << endl;
uniformDimensionedVectorField g
IOobject
"g",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
2 I make change to UEqn.H
eqnResidual = solve
UEqn() == -fvc::grad(p)+g
).initialResidual();
3 I make change to pEqn.H
U -= (fvc::grad(p)-g)/AU;
After that, I wmake to make these changes take effect.
In the constant folder, the g file is listed as follow
dimensions [0 1 -2 0 0 0 0];
value ( 0 0 -9.81 );
In the 0 folder, the p is setting as previous simulation which is without gravity
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
tubewall
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
plane
type symmetryPlane;
ziemowitzima February 14, 2013 12:59
I would suggest you to look into solvers where gravity is implemented, such as:
multiphase and heat transfer solvers.
norkistar February 15, 2013 20:06
Thanks for your kind attention. I have looked into the heat transfer solvers and I use buoyantSimpleFoam now it works
