-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Linking error in OF-1.6-ext: undefined reference to ... (http://www.cfd-online.com/Forums/openfoam-programming-development/113072-linking-error-1-6-ext-undefined-reference.html)
Hisham February 11, 2013 16:22
Dear Foamers,
I am trying to port a custom solver to OpenFOAM-1.6-ext. The compile process runs smoothly until a linking error is issued at the end of the process. The error is:
        -lfiniteVolume    -lOpenFOAM    -ltriSurface    -lmeshTools    -lmaterialConstitutiveModel    -L/home/hisham/OpenFOAM/hisham-1.6-ext/lib/linux64GccDPOpt    -lsoilZones    -lcontactModel    -pipe -lOpenFOAM -liberty -ldl  -lm -o /home/hisham/OpenFOAM/hisham-1.6-ext/applications/bin/linux64GccDPOpt/geotechFoam3
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<Foam::Vector<double> > >::type() const':
geotechFoam3.C:(.text._ZNK4Foam7IOFieldINS_5FieldINS_6VectorIdEEEEE4typeEv[Foam::IOField<Foam::Field<Foam::Vector<double> > >::type() const]+0x3): undefined reference to `Foam::IOField<Foam::Field<Foam::Vector<double> > >::typeName'
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<double> >::type() const':
geotechFoam3.C:(.text._ZNK4Foam7IOFieldINS_5FieldIdEEE4typeEv[Foam::IOField<Foam::Field<double> >::type() const]+0x3): undefined reference to `Foam::IOField<Foam::Field<double> >::typeName'
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<Foam::SymmTensor<double> > >::type() const':
geotechFoam3.C:(.text._ZNK4Foam7IOFieldINS_5FieldINS_10SymmTensorIdEEEEE4typeEv[Foam::IOField<Foam::Field<Foam::SymmTensor<double> > >::type() const]+0x3): undefined reference to `Foam::IOField<Foam::Field<Foam::SymmTensor<double> > >::typeName'
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<double> >::IOField(Foam::IOobject const&, int)':
geotechFoam3.C:(.text._ZN4Foam7IOFieldINS_5FieldIdEEEC2ERKNS_8IOobjectEi[_ZN4Foam7IOFieldINS_5FieldIdEEEC5ERKNS_8IOobjectEi]+0x52): undefined reference to `Foam::IOField<Foam::Field<double> >::typeName'
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<Foam::Vector<double> > >::IOField(Foam::IOobject const&, int)':
geotechFoam3.C:(.text._ZN4Foam7IOFieldINS_5FieldINS_6VectorIdEEEEEC2ERKNS_8IOobjectEi[_ZN4Foam7IOFieldINS_5FieldINS_6VectorIdEEEEEC5ERKNS_8IOobjectEi]+0x52): undefined reference to `Foam::IOField<Foam::Field<Foam::Vector<double> > >::typeName'
Make/linux64GccDPOpt/geotechFoam3.o: In function `Foam::IOField<Foam::Field<Foam::SymmTensor<double> > >::IOField(Foam::IOobject const&, int)':
geotechFoam3.C:(.text._ZN4Foam7IOFieldINS_5FieldINS_10SymmTensorIdEEEEEC2ERKNS_8IOobjectEi[_ZN4Foam7IOFieldINS_5FieldINS_10SymmTensorIdEEEEEC5ERKNS_8IOobjectEi]+0x52): undefined reference to `Foam::IOField<Foam::Field<Foam::SymmTensor<double> > >::typeName'
collect2: ld returned 1 exit status
make: *** [/home/hisham/OpenFOAM/hisham-1.6-ext/applications/bin/linux64GccDPOpt/geotechFoam3] Error 1
The linking error seems to come from this part of the code:
IOField<scalarField> matHistoryScalar(
                      IOobject
                      "matHistoryScalar",
                      runTime.timeName(),
                      mesh,
                      IOobject::READ_IF_PRESENT,
                      IOobject::AUTO_WRITE
                      sZones.size()
IOField<vectorField> matHistoryVector(
                      IOobject
                      "matHistoryVector",
                      runTime.timeName(),
                      mesh,
                      sZones.size()
IOField<symmTensorField> matHistorySymmTensor(
                          IOobject
                          "matHistorySymmTensor",
                          runTime.timeName(),
                          mesh,
                          sZones.size()
As far as I know I have all libraries involved included in the Make/options
EXE_LIBS = -lfiniteVolume \
    -lOpenFOAM \
    -ltriSurface \
    -lmeshTools \
    -L$(FOAM_USER_LIBBIN)
Any help is appreciated!
Best regards
Hisham
ngj February 11, 2013 16:56
Hi Hisham,
I do not think you are allowed to create an IOField< Field<Type> > in OpenFoam - at least I could not get it compiled either. Is this what you want, or do you merely need an IOField<Type>?
All the best,
Niels
ngj February 11, 2013 17:08
Hi again,
I could not help trying to get something like you sketched to compile, so along your line of thought, this might be, what you need:
        PtrList<IOField<vector> > listField(sZones.size());
        forAll( listField, fieldi)
            listField.set
                fieldi,
                new IOField<vector>
                    IOobject
                        "fjdskl",
                        runTime.timeName(),
                        mesh,
You must, however, be a bit careful with the naming "fjdskl", since all of the fields will be written to the same file name. It compiles, however, I do not know if it will work!?!
Good luck,
Niels
Hisham February 11, 2013 17:50
Originally Posted by ngj (Post 407239)
Hi again,
            listField.set
                fieldi,
                new IOField<vector>
                    IOobject
                        "fjdskl",
                        runTime.timeName(),
                        mesh,
Good luck,
Niels
EDITED
Hi Niels
Thanks a lot for the super fast response.
Actually, this code compiles and works perfectly on OpenFOAM-2.1.x. I do not know what could be the problem as the implementation of IOFields seems to be the same for both editions and I can't figure out more info from the linker message.
The idea is to have a scalar(vector/symmTensor)Field for each zone that differs in size and they all write to one file (e.g. matHistoryScalar) in the time step.
This how a file looks from a run on OF-2.1.x.
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.1.x                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      binary;
    class      scalarFieldField;
    location    "0.3";
    object      matHistoryScalar;
2 // zones
0 // first zone zero
19200 // second zone
bla bla in binary
I am afraid I understand from your proposal that each vectorField will overwrite the same file or a new file is needed for each zone!
Is there a more similar approach to what I need?
Hisham
Hisham February 11, 2013 18:24
I think I found where the problem might be. There are files in OF that are not in OF-ext:
scalarFieldIOField.H & .C
vectorFieldIOField.H & .C
symmTensorFieldIOField.H & .C
I'll try to copy them to the solver directory.
EDIT:
No they're not. They are just typedefs:
typedef IOField<scalarField> scalarFieldIOField;
And as it is compiling, it is only a link problem ...
deepsterblue February 12, 2013 00:20
You might be missing a defineTypeNameAndDebug macro in your .C file somewhere. Those are static class variables wrapped in macros.
Since you're dealing with a compound type, something like this might be necessary:
// Explicitly specify typeNames for IOFields
defineCompoundTypeName(Field<scalar>, scalarField);
addCompoundToRunTimeSelectionTable(Field<scalar>, scalarField);
defineCompoundTypeName(Field<vector>, vectorField);
addCompoundToRunTimeSelectionTable(Field<vector>, vectorField);
defineTemplateTypeNameAndDebugWithName
IOList<scalarField>, "scalarFieldList", 0
IOList<vectorField>, "vectorFieldList", 0
Hisham February 12, 2013 04:53
Hi Sandeep and Niels,
Thanks a lot Sandeep. This surely makes it work :)
namespace Foam
    typedef IOField<vectorField> vectorFieldIOField;
    typedef IOField<symmTensorField> symmTensorFieldIOField;
        vectorFieldIOField,
        "vectorFieldField",
        0
        scalarFieldIOField,
        "scalarFieldField",
        0
        symmTensorFieldIOField,
        "symmTensorFieldField",
        0
The code is copied from scalar(vector, symmTensor)FieldIOField.C and .H
Thanks again to both of you!
Best regards,
Hisham
ngj November 5, 2013 15:35
Dear Hisham and Sandeep,
I just found myself needed this solution, so thank you a lot for these posts. It was exceptionally helpful.
Kind regards,
Niels
