October 26, 2011, 11:01 |
Error with codedFixedValue BC
Hisham Elsafti
Rep Power: 17 |
Hi Foamers,
I want to use the codedFixedValue to set boundary conditions for a volScalarField to be 0 if the Y-Co larger than 2.5 and 1 otherwise. I tried this code: Code:
BoundaryName { type codedFixedValue; value uniform 0; redirectType initialWaterSurf; code #{ forAll(this, i) {operator== ((this[i]->y() > 2.5)? 0 : 1 )} #}; } Which includes should I have as well? By the way the error I get is: Code:
Setting internal values of volScalarField alpha1 --> FOAM FATAL IO ERROR: Loading a shared library using case-supplied code is not enabled by default because of security issues. If you trust the code you can enable this facility be adding to the InfoSwitches setting in the system controlDict: allowSystemOperations 1 The system controlDict is either ~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict or $WM_PROJECT_DIR/etc/controlDict Best Regards, Hisham |
October 28, 2011, 04:39 |
#2 | |
Jim Knopf
Rep Power: 15 |
i'm not sure aboute code fixed Value stuff but it seems to me that there are two Operators in your equation. The first is the equal introduced after operator and then there is the operator > before the 2.5 maybe you have to check the syntax Greetz Jim |
October 28, 2011, 04:58 |
Hisham Elsafti
Rep Power: 17 |
Hi Jim,
I appreciate your answer. I think I need more tutorials on the codedBC. The only available one, is in its header file: Code:
code #{ operator==(min(10, 0.1*this->db().time().value())); #}; I had a workaround for my problem. Nevertheless, the coded BC is a nice tool to have by one's side. Regards Hisham |
January 11, 2012, 00:20 |
bruce
Rep Power: 16 |
hi,
codedFixedValue is like other inherited from fixedValueFvPatchField<> I tested this below code for pitzDaily , simpeFoam solver. U = 100 * y^2; Code:
inlet { type codedFixedValue; value uniform (0 0 0); redirectType rampedFixedValue; code #{ // flow direction vector sys = vector(1, 0, 0); // co-ord direction of a patch vector dir = vector(0, 1, 0); // variable to be evaluated scalarField var = patch().Cf() & dir; // evaluated value scalarField value = 100 * var * var; operator==( value * sys); #}; } |
March 22, 2012, 01:57 |
Rep Power: 14 |
Hi Bruce,
If I want to apply the codedfixedValue under icoFoam application, do I need to do something extra, like adding some library and recompiling??? Thanks. |
March 13, 2013, 21:50 |
Amir Abbas Aliabadi
Rep Power: 13 |
The error message can be fixed by flagging "allowSystemOperations" in controlDict under /openfoam211/etc system directory. You should simply change it to 1 from 0. If permission is denied since you have installed OpenFoam under root directory then go to the above directory and type:
$ sudo gedit controlDict This enables you to change the setting and save the file. |
codedfixedvalue |
codedFixedValue boundary condition | wolfindark | OpenFOAM Pre-Processing | 50 | August 29, 2020 04:46 |
