how to extend solver compressibleInterFoam to consider ideal gas
Like Tree3Likes
  • 1 Post By jianfeng
  • 2 Post By mkraposhin
Old   February 19, 2013, 20:15
Default how to extend solver compressibleInterFoam to consider ideal gas
jianfeng zou
jianfeng is on a distinguished road
Hi, everyone. I am a beginner to use OpenFOAM and my interest is computing the interface between two immiscible compressible gases. It seems that current compressibleInterFoam solver is designed to solve 2 compressible, isothermal immiscible fluids. So if I could extend this solver to consider the interface between two or more ideal gases or real gas? Thanks in advance. I have no idea what should I do at all, please give me some advice.
immortality likes this.
jianfeng is offline   Reply With Quote
Old   February 20, 2013, 13:09
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Hello, Your question sounds very complex (for me).
You are interested in two-phase flow of immiscible ideal-gases, but interFoam family solvers considers for liquids with large density variation.
Are you sure that assumptions, made in interFoam solvers family are suitable for your task?
If yes, then you can do modifications easily:
1) relate compressibility of each gas to temperature psi = 1/((R/M)*T)
2) rho = psi*p
3) write temperature equation, like this:
fvm::ddt(T) + fvm::div(phi,T) - fvm::Sp(divU,T) == (... some expansion sources ...)
I solved this case and if you need, then we need to examine your problem step by step
mkraposhin is offline   Reply With Quote
Old   February 20, 2013, 13:44
jianfeng zou
Thank Kraposhin. I just intend to calculate the interaction of a shock wave with cylindrical Helium gas inhomogeneities, like the experiment conducted by J.*F. Haas and B. Sturtevant (JOURNAL OF FLUID MECHANICS, 1987). A front tracking code was used to perform this simulation in my previous work. And I hope OpenFOAM will work on the same case.
And which solver did you make the mentioned modifications, interFoam or compressibleInterFoam? Could you please give me a detailed description about where and how in the solver should be modified?
Old   February 22, 2013, 11:25
mkraposhin's Avatar
Matvey Kraposhin
Have a nice day, jianfeng
I have good news for you - in my archives i found old version of non-isothermal compressibleInterFoam (see attachment).
i made test case (based on original) and it behaves well.
But! dp/dt works very strange (for me)
wyldckat and Tolga KURUMUS like this.
Last edited by mkraposhin; February 22, 2013 at 11:28. Reason: i forgot to attach files with source code of solver and test case
Old   February 25, 2013, 01:35
jianfeng zou
Kraposhin, really thank you for your share. I have compiled the attached code successfully and I will test it with my own case. Hope it work fine.
Old   February 28, 2013, 13:43
Default OF version
Concordia_CFD
marzbali is on a distinguished road
Is the solver developed for OF-1.5 dev.?
Thanks
marzbali is offline   Reply With Quote
Old   March 1, 2013, 13:52
mkraposhin's Avatar
Matvey Kraposhin
Originally Posted by marzbali View Post
Thanks
this solver was made for OF-2.1
Density and compressiblity Mohsin FLUENT 7 June 7, 2015 22:23
Using ideal gas law and sutherland law in Fluent RyGuy FLUENT 4 June 28, 2012 02:07
Liquid instead of gas in a compressible solver !? iggor OpenFOAM 15 October 14, 2009 11:58
Imlplementing Real Gas Effect in compressbl solver saurav pathak Main CFD Forum 0 February 18, 2008 05:27
Using ideal gas law to simulate pressure decline Björn Mattsson FLUENT 5 September 5, 2005 04:03
