Compiling issue regarding to Solid Particle injector's(solidParticle) implementation
I am try to implement a solid particle injector based on solidParticles and simpleFoam.
After following some guide, now I comes up some errors that I can't solve. The error happens at where I added the code in my injectorSolidParticleCloud.C, which is renamed from solidParticleCloud.C in the Foam::solidParticleCloud::move(const dimensionedVector& g) I added the code (red) as suggested. Quote:
Can someone helps me???:confused::confused::confused: Kind regards, James |
hi James :
I met the same problem like you. Have you solved the problem yet? how did you solve it? thank you! wei |
injectorsolidparticlefoam
Dear friends
I also have the same problem with injectorsolidparticle. When compile it shows error as follows injectorSolidParticleCloud.C: In member function âvoid Foam::injectorSolidParticleCloud::move(const Foam::dimensionedVector&)â: injectorSolidParticleCloud.C:87: error: no matching function for call to âFoam::injectorSolidParticle::injectorSolidParticl e(Foam::injectorSolidParticleCloud&, Foam::vector&, Foam::label&, Foam::scalar&, Foam::vector&)â injectorSolidParticle.H:131: note: candidates are: Foam::injectorSolidParticle::injectorSolidParticle (const Foam::polyMesh&, Foam::Istream&, bool) injectorSolidParticleI.H:45: note: Foam::injectorSolidParticle::injectorSolidParticle (const Foam::polyMesh&, const Foam::vector&, Foam::label, Foam::label, Foam::label, Foam::scalar, const Foam::vector&) injectorSolidParticle.H:61: note: Foam::injectorSolidParticle::injectorSolidParticle (const Foam::injectorSolidParticle&) make: *** [Make/linux64GccDPOpt/injectorSolidParticleCloud.o] Error 1 |
do anybody knows the answer
The same problem after 3 years! :(
Hello everyone! :)
Has anybody figure out this problem so far? As I can see many people had experienced this error and notification. Any luck with the solution? I would appreciate if someone can help me, since I am quite new with this.... Thank you! Cheers! |
Use the files below in Make directory.
options: Code:
EXE_INC = \ Code:
injectorSolidParticle.C |
