February 28, 2013, 09:21 |
Problem using atmBoundaryLayerInletVelocity
zako
Rep Power: 14 |
Hi all,
I am trying to use atmBoundaryLayerInletVelocity for a very simple application however I am receiving this error i cant figure out. Thanks for any helps however small Create time Create mesh for time = 0 Reading field p Reading field U #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 log in "/lib/x86_64-linux-gnu/libm.so.6" #4 Foam::incompressible::atmBoundaryLayerInletVelocit yFvPatchVectorField::atmBoundaryLayerInletVelocity FvPatchVectorField(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #5 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompres sible::atmBoundaryLayerInletVelocityFvPatchVectorF ield>::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #6 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #7 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #8 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #9 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #11 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" Floating point exception (core dumped) |
March 3, 2013, 16:43 |
Daniel P. Combest
Zako,
"Floating point exception" is code for divide by zero or some other undefined numerical error. If you have something like a z0 = 0 and Href = 0 then there is going to be a log(0) in there for that BC. I tend to use 1e-20 instead of zero for small numbers that may induce this kind of error. Have a look at the BC itself in Code:
$FOAM_SRC/turbulenceModels/incompressible/RAS/derivedFvPatchFields/atmBoundaryLayerInletVelocity |
March 4, 2013, 06:40 |
zako
Rep Power: 14 |
Thanks a million its works
March 9, 2013, 06:40 |
Problem with atmBoundaryLayerInletVelocity
Korichi Abdelkader
Rep Power: 13 |
Hi anyone,
I have error at the forth iteration when using atmBoundaryLayerInletVelocity for a simple case I use simpleFoam solver. Anyone can help me ime = 4 DILUPBiCG: Solving for Ux, Initial residual = 0.0747753, Final residual = 0.00352462, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.0842028, Final residual = 0.00496445, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.00994555, Final residual = 9.80074e-05, No Iterations 225 time step continuity errors : sum local = 0.0137186, global = 0.000340224, cumulative = -0.000110142 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" |
March 9, 2013, 13:46 |
Lieven
Rep Power: 22 |
Welcome to the forum AbdelkaderDZ.
For the looks of it, there is something wrong with your continuity. The cumulative error is simply way too big. If you are using a standard solver, this is often caused by incompatible boundary conditions. Could you post an overview of them of all fields (pressure, velocity, ...)? Cheers, L |
March 10, 2013, 02:10 |
Re:Re:Problem with atmBoundaryLayerInletVelocity
Korichi Abdelkader
Rep Power: 13 |
Thank you Lieven
I have used the standard simplefoam with the following boundary condition for u and p: u boundary condition: boundaryField { #include "include/ABLConditions" outlet { type zeroGradient; } inlet { type atmBoundaryLayerInletVelocity; Uref $Uref; Href $Href; n $windDirection; z $zDirection; z0 $z0; value $internalField; zGround $zGround; } upperWall { type symmetryPlane; } lowerWall { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } p boundary condition boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } upperWall { type symmetryPlane; } lowerWall { type zeroGradient; } frontAndBack { type empty; } } |
March 10, 2013, 04:31 |
Lieven
Rep Power: 22 |
Nothing seems spectacular wrong with this so here are a few things you can do/check:
Does 'checkMesh' return 'mesh ok' (maybe post the final summary)? Do you get the same problem when running with smaller time step? One thing you can do is run your application using pimpleFoam instead of simpleFoam, which runs often more stable for larger time steps. Can you post the output of this here? Which turbulence model are you using? Chees, L |
November 11, 2019, 17:34 |
ATMBoundarylayer error
marco velazquez
Rep Power: 6 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
