Possibility of local mechanical turbulence implementation
Old   March 12, 2013, 18:23
Default Possibility of local mechanical turbulence implementation
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
Is there any possibility to add turbulent kinetic energy source term, k, for only specific part of any domain different from the turbulent kinetic energy value of the rest of the domain?
== 1 ==
Turbulent kinetic energy equation in kOmegaSST model of OpenFOAM 2.1.1 under kOmegaSST.C:
    // Turbulent kinetic energy equation
    tmp<fvScalarMatrix> kEqn
        fvm::ddt(k_)
      + fvm::div(phi_, k_)
      - fvm::Sp(fvc::div(phi_), k_)
      - fvm::laplacian(DkEff(F1), k_)
        min(G, c1_*betaStar_*k_*omega_)
      - fvm::Sp(betaStar_*omega_, k_)
== 2 ==
An arbitrary specified circular region in the computational domain declaration is defined under Member functions: of kOmegaSST.C:
const scalar xo = 0;
const scalar yo = 0;
const scalar zmin = -205.5;
const scalar zmax = -204.5;
const scalar radius1 = 10;
const scalar radius2 = 5;
scalar addedTurbulence; // Assumed in units m^2 / s^3.
forAll(mesh_.cells(),celll)
const vector& cellCenter=mesh_.C()[celll];
const scalar dx = cellCenter[0] - xo;
const scalar dy = cellCenter[1] -yo;
const vector r(dx, dy, 0);
if ((cellCenter[2] < zmax) &&
(cellCenter[2] > zmin) &&
(mag(r) < tipRadius) &&
(mag(r) > hubRadius))
addedTurbulence== 10;
}else{ addedTurbulence== 1; }
== 3 ==
I thought to add the addedTurbulence term would be adequate which is obviously a wrong approach:
        fvm::ddt(k_)
      + addedTurbulence
== 4 ==
addedTurbulence must be defined as volScalarField, I appreciate that. Nevertheless, I couldn't make it work with it; therefore, I tried the above approach which considers addedTurbulence term is scalar.
== 5 ==
Appreciate any piece of advice or suggestion.
Many thanks in advance.
HakikiCanakkaleli is offline   Reply With Quote
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
A reference on implementation of Spalart-Alam. Turbulence Model? Mohammad Kermani Main CFD Forum 2 December 26, 1999 02:56
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
