A question on implementing the actuationDisk to the pisoFoam solver
Old   March 21, 2013, 13:58
Default A question on implementing the actuationDisk to the pisoFoam solver
Frank Yu
frankyux is on a distinguished road
Hi folks,
I have a question on implementing the actuationDisk to the pisoFoam solver. Since I didn’t use OpenFoam too much and don’t familiar with C++, my questions may sounds stupid.
I’m currently using OpenFoam 2.0.1, I can find the implementation of actuationDisk under simpleFoam, namely windSimpleFoam, and this is my starting point.
My first attempt was, in the pisoFoam.C, first include #include "IObasicSourceList.H". Then add the actuationDisk to the right-hand-side of the UEqn.
#include "fvCFD.H"#include "singlePhaseTransportModel.H"#include "turbulenceModel.H"#include "IObasicSourceList.H"int main(int argc, char *argv[]){ #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" IObasicSourceList actuationDisks(mesh); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "readPISOControls.H" #include "CourantNo.H" // Pressure-velocity PISO corrector { // Momentum predictor fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) ); // Add resistance on the actuation disks actuationDisks.addSu(UEqn()); UEqn.relax(); if (momentumPredictor) { solve(UEqn == -fvc::grad(p)); } // --- PISO loop …. …. } turbulence->correct(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } //Info<< "End\n" << endl;
After the above modification, I got the following error message:
pisoFoam.C: In function ‘int main(int, char**)’:
pisoFoam.C:77: error: no match for call to ‘(Foam::fvVectorMatrix) ()’
where my Line77 refers to actuationDisks.addSu(UEqn());Does this mean that there is something wrong with the format of my UEqn?
I also tried to write my UEqn separately as UEqn.H, and replace the one in psioFoam,
tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevReff(U) ); // Add resistance on the actuation disksactuationDisks.addSu(UEqn());
However, I got the following error message:
In file included from pisoFoam.C:81:
UEqn.H: In function ‘int main(int, char**)’:
UEqn.H:13: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘relax’
pisoFoam.C:97: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘A’
pisoFoam.C:99: error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘H’
This one I think is because in piso loop it needs UEqn.A() and UEqn.H().
For now I just want to create a very simple example that I can involve actuationDisk in piso algorithm, anyone had this experience or any thoughts?
Thanks in advance.
Regards
Frank
frankyux is offline   Reply With Quote
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
pFinal for pisoFoam solver L1011 OpenFOAM 3 March 16, 2011 11:59
Question abt. the Riemann analytic solver jinwon Main CFD Forum 0 July 16, 2007 14:11
question about implementing boundary conditions saygin Main CFD Forum 0 July 6, 2006 07:08
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
