March 11, 2013, 04:46 |
compute U in p.Eqn in interfoam
Rep Power: 13 |
Hi to all,
i am a bit confused in the computed of U in the pEqn.H of interFoam why is computed as follow? U += rAU*fvc::reconstruct((phi - phiU)/rAUf) I compare it with the PISO algorithm in wich U is computed as: U -= rUA*fvc::grad(p); thanks to all |
March 18, 2013, 08:53 |
Fumiya Nozaki
Rep Power: 18 |
This topic is discussed in several threads:
The following documents cover most of the points about interFoam including this topic:
Regarding the "reconstruct" function, you might want to see the following thread: Best regards, Fumiya Last edited by fumiya; March 19, 2013 at 21:58. |
March 18, 2013, 09:23 |
Rep Power: 13 |
Thank you very much for your help
I have another question: in the first document that you send me the compression term is discretized as show in 114 but in i look in the code and the discretization is different. In the code, in fact, is used a quadratic compression scheme as follow: min(max(4*min(phiP*(1 - phiP), phiN*(1 - phiN)), 0), 1) the two scheme are similar?what is better? Thank you very much for your willingnes |
Compute shear stress interFoam | hsieh | OpenFOAM Post-Processing | 58 | June 20, 2022 04:15 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Evaporation due to Heat Transport using InterFoam (Correct Implementation?) | ovie | OpenFOAM | 14 | August 3, 2019 07:00 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
How to compute total liquid volume of the whole domain | hsieh | OpenFOAM Post-Processing | 2 | July 13, 2007 18:18 |
