Home > Forums > OpenFOAM Programming & Development
checkerboard pressure and velocity field
Old   April 1, 2013, 17:04
Default checkerboard pressure and velocity field
pascool is on a distinguished road
Hi foamers,
I'm computing the periodic flow through a ribbed duct. To achieve the desired flow rate, I coupled simpleFoam and channelFoam as follows:
   Info<< "\nStarting time loop\n" << endl;
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity SIMPLE corrector
        // U equation--------------------------------------------------------------------------------------------
       // Momentum predictor
       tmp<fvVectorMatrix> UEqn
           fvm::div(phi, U)
         + turbulence->divDevReff(U)
           flowDirection*gradP
       UEqn().relax();
       sources.constrain(UEqn());
       solve(UEqn() == -fvc::grad(p));
      // p equation ---------------------------------------------------------------------------------------------
          p.boundaryField().updateCoeffs();
          volScalarField rAU(1.0/UEqn().A());
          U = rAU*UEqn().H();
          UEqn.clear();
          phi = fvc::interpolate(U, "interpolate(HbyA)") & mesh.Sf();
          adjustPhi(phi, U, p);
          // Non-orthogonal pressure corrector loop
          while (simple.correctNonOrthogonal())
              fvScalarMatrix pEqn
                  fvm::laplacian(rAU, p) == fvc::div(phi)
              pEqn.setReference(pRefCell, pRefValu             pEqn.solve();
              if (simple.finalNonOrthogonalIter())
                  phi -= pEqn.flux();
          #include "continuityErrs.H"
          // Explicitly relax pressure for momentum corrector
          p.relax();
         // Momentum corrector
          U -= rAU*fvc::grad(p);
          U.correctBoundaryConditions();
          sources.correct(U);
          turbulence->correct();
      // Correct driving force for a constant mass flow rate
      // Extract the velocity in the flow direction
      dimensionedScalar magUbarStar =
            (flowDirection & U)().weightedAverage(mesh.V());
      // Calculate the pressure gradient increment needed to
      // adjust the average flow-rate to the correct value
      dimensionedScalar gragPplus =
          (magUbar - magUbarStar)/rAU.weightedAverage(mesh.V());
       U += flowDirection*rAU*gragPplus;
       gradP += gragPplus;
       Info<< "Uncorrected Ubar = " << magUbarStar.value() << tab
           << "pressure gradient = " << gradP.value() << endl;
       runTime.write();
       #include "writeGradP.H"
       Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
           << "  ClockTime = " << runTime.elapsedClockTime() << " s"
           << nl << endl;
    Info<< "End\n" << endl;
    return 0;
The code works, but I get a strange checkerboard pattern.
Has anybody an idea where it may come from and how I could remedy this issue? I already tried different meshes.
Any help appreciated!!!
Best,
Pascal
pascool is offline   Reply With Quote
Old   April 1, 2013, 17:13
The mentioned checkerBoard pattern:
Thread Tools
Trackbacks are On
How to get the velocity field from the pressure field Hermano Main CFD Forum 2 November 29, 2011 09:32
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
