Home > Forums > OpenFOAM Programming & Development
How could I modify the pEqn.H by adding ajustPhi() in twoPhaseEulerFoam
Old   April 2, 2013, 11:32
Default How could I modify the pEqn.H by adding ajustPhi() in twoPhaseEulerFoam
Charlie
cheng1988sjtu is on a distinguished road
Hi Foamers,
When I use zeroGradient pressure condition at the wall, I could see pressure sigularity at the pReff(), and I searched in the forum, and found that that's due to that fact that there is no adjustPhi after the buoyancy term.
So, I added the following lines before phi = alphaf*phia + betaf*phib;
adjustPhi(phia, Ua, p);
adjustPhi(phib, Ub, p);
however, after I added this lines, I could see that my Dispersed volume fraction is decreasing though slowly.
Could anyone give me a hint on how adjustPhi() should work?
Thanks
Zhen Cheng
cheng1988sjtu is offline   Reply With Quote
Old   April 2, 2013, 15:36
Charlie
Never mind, I figured out that the mass reduction is not due to the adjustPhi, and FYI, this approach do eliminate the pressure singularity at the zeroGradient boundary (p).
Charlie
Old   April 3, 2013, 11:05
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Greetings Zhen Cheng,
Just curious about your findings,
What was the source of mass reduction in your simulations? Just in case others run into the same issue.
Dan
Dan
Find me on twitter @dancombest and LinkedIn
chegdan is offline   Reply With Quote
Old   March 3, 2014, 10:13
Josebus van Zyl
Popmech is on a distinguished road
Hi, I am using a modified version of the twoPhaseEulerFoam solver to model a mixing vessel with settling particles. I have a zero-gradient pressure condition on all surfaces including the free-surface which is represented by a symmertryPlane type boundary condition. I suffer from a similar problem with a singularity occurring at the pReffCell in the simulation which causes the volume fractions to be solved incorrectly. I have tried implementing the adjustPhi call as described in this thread, though this causes an error stating there is no outflow boundary to adjust. Does someone know how to work around this problem?
Kind Regards, JVZ
Popmech is offline   Reply With Quote
Thread Tools
Trackbacks are On
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 18:16
