interFoam: contact angle
Like Tree1Likes
  • 1 Post By kathrin_kissling
Old   October 1, 2009, 06:28
Default interFoam: contact angle
ala
Alicja M
ala is on a distinguished road
Dear community,
I have a question concerning interFOAM: Where/How is the contactAngle during the simulation calculated? Respectively where/how gets the contactAngle respected during the simulation?Unfortunately I cannot figure out the corresponding code part.
Any hints/help would be appreciated!
Thanks in advance,
Ala
ala is offline   Reply With Quote
Old   October 2, 2009, 05:26
Kathrin Kissling
kathrin_kissling is on a distinguished road
Take a look into ../src/transportProperties/interfaceProperties/interfaceProperties.C / interfaceProperties.H the member function is called correctContactAngle. The definite calculation of the contact angle is in src/transportProperties/interfaceProperties/calculateContactAngle and in the subfolders. Just take a look. If you have any questions, feel free to ask Kathi
kathrin_kissling is offline   Reply With Quote
Old   October 5, 2009, 11:04
ala
Alicja M
Hi Kathi,
thank you for your reply. correctContactAngle is for correcting dynamicContactAngle, after the gamma equation being solved. But how gets the constantContactAngle during the simulation respected?
Greetings, Ala
Old   October 6, 2009, 07:50
Kathrin Kissling
Hi ala,
it is respected in UEqn.H (in case you enable the momentum corrector) and in the pEqn.
There is one term
fvc::interpolate(interface.sigmaK())*fvc::snGrad(g amma))
which is described by Brackbill 1992.
sigmaK is a member function of interfaceProperties class. And calls calculateContact angle.
Hope this helps
Kathrin
Old   September 27, 2010, 11:24
ala
Alicja M
Thank you : ) it had helps,
greetings, ala
Old   September 28, 2010, 11:41
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Dear all,
I would like to know the differences between constant contact angle and dynamic contact angle in OF. I did some simulation with steady moving bubble in a straight channel with prescribed constant contact angle (30 degree) at the wall. What I expected is that the contact angle close to the wall at the front and the rear bubble is similar. But what I got from OF is not (you can see in the figure).
I did check the code of constantAlphaContactAngle and found that there is no function to calculate new contact angle based on alpha_advance, alpha_reduce and u_theta as I saw in dynamicAlphaContactAngle. However, I found this line in interfaceProperties.C:
scalarField theta =
convertToRad*acap.theta(U_.boundaryField()[patchi], nHatp)
which calculate contact angle at the wall. Here, we can see the appearance of U_.boundaryField()[patchi]. So U must be taken into account in calculating contact angle in OF even we use constantAlphaContactAngle option. That might explain my observation.
Do you have any other ideas about that?
Regards,
Duong
duongquaphim is offline   Reply With Quote
Old   October 12, 2010, 08:29
Default compiling error
mohsen kh
mohsenkh599 is an unknown quantity at this point
Hi every body,
I have a problem when I want to compile a model.
the error is:
viscoelasticLaws/mohsen/mohsen.C:159: error: no match for ‘operator==’ in ‘Foam:perator+(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::SymmTensor<double>](((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >&)((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >*)(& Foam::fvm::div(const Foam::surfaceScalarField&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::SymmTensor<double>](((Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))) == Foam:perator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::Tensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator&(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator-(const Foam::dimensioned<Type>&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Form = Foam::SymmTensor<double>, Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::scalar&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>*)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))))))))))))))))’
and the model is :
// Velocity gradient tensor
volTensorField L = fvc::grad( U() );
// Convected derivate term
// volTensorField C = tau_ & L;
// vorticity term
volTensorField Vor = L - L.T();
// Twice the rate of deformation tensor
volSymmTensorField twoD = twoSymm( L );
// fc
scalar fc = 0.5; //1 - 27 * det( a_ );
//double dot term
// volSymmTensorField mk = -( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ );
// Stress transport equation
tmp<fvSymmTensorMatrix> aEqn
fvm::ddt(a_)
+ fvm::div(phi(), a_)
( 1 / 2 ) * ( Vor & a_ - a_ & Vor ) + ( 1 / 2 ) * keisi_ * ( twoD & a_ + a_ & twoD + 2 * ( ( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( 1 - fc ) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ ) ) + 2 * ci_ * twoD & ( I_ - 3 * a_ )
//+ twoSymm( C )
//- zeta_ / 2 * ( (tau_ & twoD) + (twoD & tau_) )
//- fvm::Sp( epsilon_ / etaP_ * tr(tau_) + 1/lambda_, tau_ )
aEqn().relax();
solve(aEqn);
// Viscoelastic stress
tau_ = (etaP_ / keisi_) * (a_ - I_);
where "a" , "tau" and "I" are symmetric tensors and "Vor" is asymmetric tensor. and the others are constant parameters.
best
mohsenkh599 is offline   Reply With Quote
Old   October 12, 2010, 08:39
Kathrin Kissling
Hi
likely the term
doesnt match the right side of your equation system. Obviously it should be of type of type symTensorMarix.
Can you check whether this is ok? Just put an Info staement including the term and look what field is printed.
I'm not really sure whether you are in the correct thread since this one focusses on contact angles while your problem seems to be viscoelastic...
Best
Kathrin
Old   October 12, 2010, 08:43
Kathrin Kissling
I just recognized now...
please do not crosspost!
People don't like their threads being spamed. Please keep to the forum netiquette otherwise it is likely you don't get answers at all!
Best Kathrin
joshmccraney likes this.
Old   October 27, 2010, 07:23
Stefan Herbert
herbert is on a distinguished road
scalarField theta =
Hi Duong,
I don't think so. U is not used when you use constantAlphaContactAngle. It has only to be given to the function theta() to match both cases: constant and dynamic contactAngle-BC.
There must be some other effects, that cause your bubble not being symmetric. Please keep in mind, that the contact angle is only corrected in the first cell layer. Of course inertia or some other effects influence the shape of the interface as well, and these effects are not symmetric.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   February 26, 2014, 03:18
idefix is on a distinguished road
I know the thread is older but I still didn´t get some points, perhaps someone can help me:
Hi ala,
There is one term
Hope this helps
Kathrin
Does anyone know a good book/ paper where the constantAlphaContactAngle is explained?
I am not familiar with the code and I can´t understand what is going on by looking at the code.
I just want to know which equation is calculated when I use the boundary condition constantAlphaContactAngle .
Thanks a lot
idefix is offline   Reply With Quote
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Implemening Slip bc and Dynamic contact angle in interFoam asaha OpenFOAM Running, Solving & CFD 2 July 29, 2010 15:49
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
About the Contact Angle Flora FLUENT 2 March 8, 2007 02:07
