Dirichlet–Neumann Partitioning BCs
Hi all,
I have to implement the Dirichlet–Neumann Partitioning BCs for my solver that treats two different regions (fluid and solid). Is there any preconfigured BC in the framework of OpenFoam? Thanks Regards Giancarlo |
Hi Giancario,
I am not familiar with the term "Dirichlet-Neumann Partitioning", however, maybe the mixedFvPatch class is what you need. In this class you can switch (smoothly) from a dirichlet to a neumann condition depending on the instantaneous dynamics of the system. I use it in the binary fashion to switch between fixed value and zero gradient, where the choice depends on the internal value of some concentration field. Kind regards Niels |
Hi Giancarlo,
I fear there is no Direchlet-Neumann BC coded by default in OF and that you have to develop your owns. You can find a lot of informations in http://www.personal.psu.edu/dab143/O...ven_slides.pdf and its associated tutorial http://www.personal.psu.edu/dab143/O...erTraining.tgz. The relaxation factors are quite important in this example. @++ Cyp |
Thanks a lot Cyp. This materials is fantastic. It's just what I was looking for.
Regards Giancarlo |
In case you still read here, have you got this working?
I'm currently implementing something similar for electric potential between different regions. By now OpenFOAM has a boundary condition for the temperature that uses an approach like this, called turbulentTemperatureCoupledBaffleMixed. I adopted it to my needs, but I don't understand the weighting factor in the mixed formulation. Why is it set to this value? Does it help convergence if this value is used instead of some arbitrary value between 0 and 1 (like 0.5)? Furthermore, how does relaxation help here? My current solver doesn't use relaxation (it's transient), and it requires quite some iterations initially until a consistent solution is reached (up to 30 in a test case I made). The link mentioned using Aitken's delta˛ method (see here), which is basically a quadratic extrapolation of the convergence series of the field. In its current implementation, OpenFOAM doesn't use this. Have you implemented this? Is it worth it for transient cases? I believe that the convergence should be better in transient cases because the solution changes only a bit between steps. |
After some more investigation I figured out that relaxation didn't refer to the field relaxation, but rather to the coupling between the patches of different regions.
I also compiled the MRConjugateHeatFoam solver with OF2.3, but it doesn't calculate any sensible results and the solution of the example looks very incorrect. Has anyone tried this solver with success? |
MRConjugateHeatFoam
Hi Chirss85,
I worked with the MRConjugateHeatFoam. In my case, I validated the solver with some experimental cases, and the results were really good. BTW, my problem was heat conduction between two solids (i.e. silicon on a glass substrates) due to laser annealing. Cheers shakil Quote:
