-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Manipulating the alpha1-field after every time step (http://www.cfd-online.com/Forums/openfoam-programming-development/117410-manipulating-alpha1-field-after-every-time-step.html)
idefix May 8, 2013 03:36
I am using the interFoam-solver. Alpha1 is characterizing the volume fraction (alpha1= 0 means: there is only gas in the cell, alpha1=1 means: there is only liquid in the cell).
Now I´ve got the problem, that alpha1 is getting negative or greater than 1 which is not realistic.
My idea is to "correct" the alpha1 after every time step.
I need something which goes into every cell: If alpha1 is negative or nearly 0 (for example 0.1e-6), alpha1 should be put to 0. If alpha1 is greater than or nearly 1, alpha1 should be put to 1.
I would put this function in tha alphaEn.H - file after the for loop.
Can anybody help me?
Thanks a lot
Phicau May 8, 2013 04:02
I would not suggest doing this, as MULES handles itself the boundedness, continuity and conservation of alpha1. Although you may obtain vales slightly lower than 0 or larger than 1, if your BCs are correctly set, these will only be on the order of machine precision.
However, to do what you asked:
threshold = 0.01; // You name it
alpha1 = alpha1 * pos(alpha1-threshold) * neg(alpha1-1+threshold) + pos(alpha1-1+threshold)
Best,
Pablo
sophie_l May 13, 2013 11:03
Hi Pablo,
I am using interFoam/waveFoam as well. I remember in the code, the value of alpha1 is restricted between 0 and 1. However, the case I am running at the moment gives out results like this, where Max(alpha1) = 1.57337. But the case is still running even though.
Courant Number mean: 0.00685244 max: 0.558313
Interface Courant Number mean: 6.62914e-05 max: 0.558313
deltaT = 0.00132421
Time = 0.186161
MULES: Solving for alpha1
Liquid phase volume fraction = 0.666668 Min(alpha1) = 0 Max(alpha1) = 1.16009
Liquid phase volume fraction = 0.666668 Min(alpha1) = 0 Max(alpha1) = 1.57337
GAMG: Solving for p_rgh, Initial residual = 5.1474e-05, Final residual = 6.30767e-06, No Iterations 1
time step continuity errors : sum local = 1.13037e-05, global = -3.39547e-08, cumulative = -6.81206e-06
DILUPBiCG: Solving for epsilon, Initial residual = 0.00528157, Final residual = 7.39422e-09, No Iterations 7
DILUPBiCG: Solving for k, Initial residual = 0.00656354, Final residual = 3.16796e-09, No Iterations 8
ExecutionTime = 1408.43 s ClockTime = 1465 s
I am thinking it should be due to the input boundary conditions, however, I haven't got a clue where the check should start with. Do you some suggestions on this please?
Thanks a lot!
Sophie
Phicau May 13, 2013 11:30
Hi
it is very likely that your alpha1 unboundedness is caused by the BCs. I suggest you take a look at this post for BC reference:
http://www.cfd-online.com/Forums/ope...ed-topics.html
if that does not solve your problems, explain your case there and I am sure they will be able to help you.
Best,
Pablo
ngj May 13, 2013 15:24
Hi Sophie,
From the snap-shot of the log file, it is clear that:
1. You are not solving the momentum equation.
2. You are only solving the pressure equation one (1) time per time step.
If you relate that with the fact that interFoam/waveFoam is based on a PIMPLE-algorithm, then you will have no chance what so ever in obtaining mass conservation on the cell level; in your case the error in mass conservation is considerable. This is most probably the reason for the unboundedness of alpha1.
So: start solving for the momentum equation and have 3-4 iterations in the pressure equation per time step. This will greatly improve on your mass conservation problems and therefore improve on the boundedness of alpha1.
Kind regards,
Niels
sophie_l May 13, 2013 16:00
Hi Niels,
Thank you so much for your reply. Really appreciate your help so far!
That's quite inspiring really. I'll resort to the code to work it out. By the way, I am using OF 1.7.1 based on PISO algorithm. However, in the cases I ran earlier, I didn't see alpha1 could be larger than 1.5, at most 1.0*.
Many thanks,
Sophie
ngj May 13, 2013 16:14
Hi Sophie,
If you are using the PISO algorithm, the problem is at least as bad as using PIMPLE (though, if your relaxing factors are 1, then the results should be identical).
You do not need to modify/read the code, but merely change some keywords in fvSolution.
Furthermore, I can recommend that you read the section on the PISO algortihm in
@book { Ferziger2002,
Author = {Ferziger, J. H. and Peric, M},
Title = {Computational Methods for Fluid Dynamics},
Publisher = {Springer},
Year = {2002},
Edition = {3rd},
which will aid you in understand the importance of the settings for the PISO-algorithm.
Kind regards,
Niels
sophie_l May 13, 2013 16:27
Hi Niels,
Thanks a lot!
Fortunately, I've borrowed this book from the library. I'll read this part right now.
Cheers,
Sophie
idefix May 14, 2013 03:01
the discussion is really helpful for me and I have got one question to it.
My simulations are not running very well. Soon after the beginning the velocities are increasing and as a result my time step is decreasing till the simulation stopps ( I am using adjustableRunTime). The turbulent viscosity is getting very small too.
I am using the k-epsilon-model.
At the beginning I thought that alpha1 is the reason for this behaviour but the discussion here gives some hints that the problem could be somewhere else.
Is there a possiblity to change something in the fvSolution-file so that the simulation get stable?
At the moment my fvSolution-file looks like:
solvers
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-10;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0.05;
p_rghFinal
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0;
"(U|k|epsilon)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
"(U|k|epsilon)Final"
solver PBiCG;
tolerance 1e-08;
relTol 0;
PIMPLE
momentumPredictor no;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nAlphaCorr 1;
nAlphaSubCycles 4;
cAlpha 2;
My log-file is:
Courant Number mean: 0.001746147011 max: 0.512101182015
Interface Courant Number mean: 2.50102364228e-05 max: 0.0844578543383
deltaT = 3.4147974996e-18
Time = 0.0041231153508954621
Phase-1 volume fraction = 0.0910985755396 Min(alpha1) = -8.28923892037e-44 Max(alpha1) = 1.00000001104
Phase-1 volume fraction = 0.0910985743502 Min(alpha1) = -3.51986718636e-44 Max(alpha1) = 1.00000001103
Phase-1 volume fraction = 0.091098573153 Min(alpha1) = -4.940549133e-45 Max(alpha1) = 1.00000001103
Phase-1 volume fraction = 0.0910985719483 Min(alpha1) = -3.27296438965e-44 Max(alpha1) = 1.00000001102
DICPCG: Solving for p_rgh, Initial residual = 0.0269677660092, Final residual = 0.00113281797768, No Iterations 2
time step continuity errors : sum local = 3.66942289335e-07, global = 1.44616781464e-07, cumulative = 0.000266660876022
DICPCG: Solving for p_rgh, Initial residual = 0.00387752776814, Final residual = 0.000186226585041, No Iterations 13
time step continuity errors : sum local = 6.10538629187e-08, global = 1.86907321117e-08, cumulative = 0.000266679566754
DICPCG: Solving for p_rgh, Initial residual = 0.000664946844126, Final residual = 9.53727056345e-08, No Iterations 120
time step continuity errors : sum local = 3.12780800404e-11, global = 1.96037099123e-12, cumulative = 0.000266679568714
DILUPBiCG: Solving for epsilon, Initial residual = 0.00538752754077, Final residual = 4.08274384377e-10, No Iterations 2
DILUPBiCG: Solving for k, Initial residual = 0.00378438227684, Final residual = 2.31895835788e-09, No Iterations 1
max(k) = max(k) [0 2 -2 0 0 0 0] 2.60958163608e+13 min(k) = min(k) [0 2 -2 0 0 0 0] 0.00172278530058
max(epsilon) = max(epsilon) [0 2 -3 0 0 0 0] 2.84510295356e+22 min(epsilon) = min(epsilon) [0 2 -3 0 0 0 0] 15.772024055
max(U) = max(U) [0 1 -1 0 0 0 0] (1.3707489336e+12 2.3034155804e+12 9.11378593063e+12) min(U) = min(U) [0 1 -1 0 0 0 0] (-1.87325084502e+12 -3.151035603e+12 -5.6941716128e+12
ExecutionTime = 29474.2 s ClockTime = 29593 s
Thanks a lot
ngj May 14, 2013 03:55
Hi Idefix,
Try running your simulation without a turbulence closure. Your turbulence quantities are diverged, so poor boundary conditions on k/epsilon could be the source of your crash.
Kind regards
Niels
idefix May 14, 2013 04:29
Hi Niels,
thanks for your answer but I am not so familiar with OpenFoam.
How can I run my simulation without turbulence closure?
Going away from URANS?
thanks again
Idefix
ngj May 14, 2013 05:07
Hi Idefix,
Open the file
constant/RASProperties
and change your current RASModel to
RASModel    laminar;
Kind regards
Niels
idefix May 14, 2013 06:34
Hi Niels,
in my case I´ve got a pipe flow and the Reynolds-numbers says that I have got a turbulent flow.
For my understanding I should calculate the flow turbulent.
Is there something else I can try?
Thanks a lot,
Idefix
ngj May 14, 2013 06:53
Hi Idefix,
My suggestion is only meant for debugging. Turning off the turbulence, you can lower the complexity and see, whether the turbulence model is the cause of your problems. If yes, you know that you need to change e.g. the boundary conditions to stabilise the model.
You could also try to use upwind on all of the divergence schemes in fvSchemes.
Kind regards
Niels
