recompiling moveEngineMesh
I would like to recompile the moveEngineMesh solver/utility. I made a copy and changed its name (to moveEngineMeshKD1), recompile and run. Everything went smooth. Then i also made a copy of engineMesh.H/C and changed its name to engineMeshKD1.H/C.
Then i did a small modification of my copy of engineMeshKD1.H/C - i changed the names of boundaries (pistonHead, linear and piston). I modified the #include line in the top of moveEngineMeshKD1.c to include the new modified file. I added the file path to options. I recompiled and then run. The new solver/utility showed an error: --> FOAM FATAL ERROR: cannot find piston patch From function engineMesh::engineMesh(const IOobject& io) in file engineMesh/engineMesh/engineMesh.C at line 79. FOAM exiting It seems my modified engineMeshKD1 was not included. I have no idea why is that. I did not include the engineMesh.h, i changed it to engineMeshKD1.h. Any idea what am i doing wrong? I attached the code changes below. Regards, Klemen ------------------ wmake ------------------ Making dependency list for source file moveEngineMeshKD1.C SOURCE=moveEngineMeshKD1.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/engine/lnInclude -I/home/klemen/OpenFOAM/klemen-2.2.0/applications/utilities/engineMeshKD1 -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/moveEngineMeshKD1.o g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/engine/lnInclude -I/home/klemen/OpenFOAM/klemen-2.2.0/applications/utilities/engineMeshKD1 -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/moveEngineMeshKD1.o -L/opt/openfoam220/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -lengine -ldynamicMesh -lOpenFOAM -ldl -lm -o /home/klemen/OpenFOAM/klemen-2.2.0/platforms/linuxGccDPOpt/bin/moveEngineMeshKD1 klemen@klemen-VirtualBox:~/OpenFOAM/klemen-2.2.0/applications/utilities/moveEngineMeshKD1$ ------------------ moveEngineMeshKD1 ------------------ #include "fvCFD.H" #include "engineTime.H" #include "engineMeshKD1.H" // CHANGE // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createEngineTime.H" # include "createEngineMesh.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.theta() << " CA-deg\n" << endl; mesh.move(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } ------------------ engineMeshKD1.c ------------------ #include "engineMeshKD1.H" #include "dimensionedScalar.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { defineTypeNameAndDebug(engineMesh, 0); defineRunTimeSelectionTable(engineMesh, IOobject); } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::engineMesh::engineMesh(const IOobject& io) : fvMesh(io), engineDB_(refCast<const engineTime>(time())), pistonIndex_(-1), linerIndex_(-1), cylinderHeadIndex_(-1), deckHeight_("deckHeight", dimLength, GREAT), pistonPosition_("pistonPosition", dimLength, -GREAT) { bool foundPiston = false; bool foundLiner = false; bool foundCylinderHead = false; forAll(boundary(), i) { if (boundary()[i].name() == "compPistonHead") // CHANGE { pistonIndex_ = i; foundPiston = true; } else if (boundary()[i].name() == "compLiner") // CHANGE { linerIndex_ = i; foundLiner = true; } else if (boundary()[i].name() == "compCylinderHead") // CHANGE { cylinderHeadIndex_ = i; foundCylinderHead = true; } } reduce(foundPiston, orOp<bool>()); reduce(foundLiner, orOp<bool>()); reduce(foundCylinderHead, orOp<bool>()); if (!foundPiston) { FatalErrorIn("KD: engineMesh::engineMesh(const IOobject& io)") << "KD cannot find patch" << exit(FatalError); } if (!foundLiner) { FatalErrorIn("KD: engineMesh::engineMesh(const IOobject& io)") << "KD cannot find patch" << exit(FatalError); } if (!foundCylinderHead) { FatalErrorIn("KD: engineMesh::engineMesh(const IOobject& io)") << "KD cannot find patch" << exit(FatalError); } { if (pistonIndex_ != -1) { pistonPosition_.value() = -GREAT; if (boundary()[pistonIndex_].patch().localPoints().size()) { pistonPosition_.value() = max(boundary()[pistonIndex_].patch().localPoints()).z(); } } reduce(pistonPosition_.value(), maxOp<scalar>()); if (cylinderHeadIndex_ != -1) { deckHeight_.value() = GREAT; if (boundary()[cylinderHeadIndex_].patch().localPoints().size()) { deckHeight_.value() = min ( boundary()[cylinderHeadIndex_].patch().localPoints() ).z(); } } reduce(deckHeight_.value(), minOp<scalar>()); Info<< "deckHeight: " << deckHeight_.value() << nl << "piston position: " << pistonPosition_.value() << endl; } } // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::engineMesh::~engineMesh() {} |
