Home > Forums > OpenFOAM Programming & Development
given field does not correspond to patch !!
Old   May 16, 2013, 14:55
Default given field does not correspond to patch !!
Samer
SamerAli is on a distinguished road
Dear All
I am trying to set heat flux at the interface of each coupled fluid-solid region:
Info << "Setting Heat Flux on solid patch" << endl;
forAll (fluidpatchesNames,s)
word fluidPatchName=fluidpatchesNames[s];
word solidPatchName=solidpatchesNames[s];
word fluidZoneName=fluidzonesNames[s];
word solidZoneName=solidzonesNames[s];
Info<<"fluidZoneName "<<fluidZoneName<<endl;
Info<<"solidZoneName "<<solidZoneName<<endl;
label solidPatchID
stressMesh.boundaryMesh().findPatchID(solidPatchNa me)
Info<<solidPatchID<<endl;
HeatFluxFvPatchScalarField& Heat=
refCast<HeatFluxFvPatchScalarField>
Ts.boundaryField()[solidPatchID]
if (solidPatchID < 0)
FatalErrorIn(args.executable())
<< "Problem with finding solid patch"
<< abort(FatalError);
label solidZoneID =
stressMesh.faceZones().findZoneID(solidZoneName);
Info<<solidZoneID<<endl;
if (solidZoneID < 0)
<< "Problem with finding solid zone"
label fluidPatchID =
mesh.boundaryMesh().findPatchID(fluidPatchName);
Info<<fluidPatchID<<endl;
if (fluidPatchID < 0)
<< "Problem with finding fluid patch"
label fluidZoneID =
mesh.faceZones().findZoneID(fluidZoneName);
Info<<fluidZoneID<<endl;
if (fluidZoneID < 0)
<< "Problem with finding fluid zone"
scalarField fluidPatchHeatFlux=
kF.value()*Tf.boundaryField()[fluidPatchID].snGrad();
scalarField fluidZoneHeatFlux
mesh.faceZones()[fluidZoneID].size(),
0.0
label fluidPatchStart =
mesh.boundaryMesh()[fluidPatchID].start();
Info<<fluidPatchStart<<endl;
forAll(fluidPatchHeatFlux, i)
fluidZoneHeatFlux
mesh.faceZones()[fluidZoneID].whichFace(fluidPatchStart + i)
fluidPatchHeatFlux[i];
Info<<"TEST"<<endl;
// Parallel data exchange: collect heat flux field on all processors
reduce(fluidZoneHeatFlux, sumOp<scalarField>());
Info<<"TEST2"<<endl;
scalarField solidZoneHeatFlux =
interpolatorFluidSolid.faceInterpolate
fluidZoneHeatFlux
Info<<"Flag"<<endl;
label solidPatchStart =
stressMesh.boundaryMesh()[solidPatchID].start();
Info<<solidPatchStart<<endl;
forAll(solidPatchHeatFlux, i)
solidPatchHeatFlux[i] =
solidZoneHeatFlux
stressMesh.faceZones()[solidZoneID]
.whichFace(solidPatchStart + i)
Heat.HeatFlux()=solidPatchHeatFlux;
scalar totalHeatFlux =
gSum
solidPatchHeatFlux
*stressMesh.magSf().boundaryField()[solidPatchID]
Info << "Total HeatFlux on "<<solidPatchName<<" "
<< totalHeatFlux << endl;
but when i run my simulation all i get is the following error:
--> FOAM FATAL ERROR:
given field does not correspond to patch. Patch size: 225 field size: 150
From function PatchToPatchInterpolation::faceInterpolate(const Field<Type> ff)
can anyone help?
Thank you in advance
SamerAli is offline   Reply With Quote
Old   November 27, 2013, 10:01
styleworker is on a distinguished road
Have you solved the problem?
styleworker is offline   Reply With Quote
Thread Tools
Trackbacks are On
CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 125 July 1, 2015 21:09
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Fluent3DMeshToFoam simvun OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 48 May 14, 2012 05:20
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
