June 24, 2021, 04:56 |
CodedFixedValue Issue when Creating .so file
Leo
Rep Power: 5 |
Hi all,
I am new to OpenFoam, and I have a problem with the implementation of the boundary condition. The model I am trying to implement is composed of two rotating bicycle wheels. In order to model the rotation of the wheels, I wrote a customised boundary condition using CodedFixedValue. Here is the following code implemented in the U file of the 0 folder : code #{ const vectorField& Cf = patch().Cf(); vectorField& field = *this; const scalar x_av = 0.370607; const scalar z_av = 0.478752; const scalar R = 0.36; const scalar V = 18; forAll(Cf, faceI) { field[faceI] = vector(-V*(boundaryPatch.Cf()[faceI].z()-z_av)/R, 0, -V*(boundaryPatch.Cf()[faceI].x()-x_av)/R); } #}; The problem is that, when I run the simulation, the following error appears : Could not load "/home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libMyRotatingWheels_668403437a803347164f91e9228000 d23f90980a.so" /home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libMyRotatingWheels_668403437a803347164f91e9228000 d23f90980a.so: cannot open shared object file: No such file or directory Invoking wmake libso /home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/dynamicCode/MyRotatingWheels wmake libso /home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/dynamicCode/MyRotatingWheels /opt/OpenFOAM/OpenFOAM-v2006/wmake/wmake: line 624: make: command not found /opt/OpenFOAM/OpenFOAM-v2006/wmake/wmake: line 627: make: command not found wmake error: file 'Make/linux64Gcc63DPInt32Opt/sourceFiles' could not be created in /home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/dynamicCode/MyRotatingWheels --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/MyRotatingWheels/platforms/linux64Gcc63DPInt32Opt/lib/libMyRotatingWheels_668403437a803347164f91e9228000 d23f90980a.so" file: /home/vcourreges/OpenFOAM/OpenFOAM-v2006/ALTEN/6_OpenFoam_Party/2roues/0/U.boundaryField.RoueAVV9 at line 57 to 83. From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const in file db/dynamicLibrary/codedBase/codedBase.C at line 237. FOAM exiting After a few hours trying to figure out the problem, the only things I can tell about this error is that the .so file associated with the customised boundary file cannot be loaded, and maybe because OF does not acces to the .C and .H files of the src folder (I am not sure at all about that). Thank you for your help, I hope I have given enough information to enable you to find a solution ! Kind regards |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
