-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Canopy model implemented but Warning: ZN4Foam14incompressible8RASModel11printCoeffsEv (http://www.cfd-online.com/Forums/openfoam-programming-development/118243-canopy-model-implemented-but-warning-zn4foam14incompressible8rasmodel11printcoeffsev.html)
be_inspired May 23, 2013 09:42
Hi all,
I have just implemented a generic canopy model over OF2.1.1 based on kEpsilon turbulence model ( 4 parameters controls the type of canopy model) based on the work of Mochida and others. The solver simpleFoam has been also modified to take into account the modification over U equation.
Until now the solver runs correctly and the results looks fine when comparing with the benchmarking of Mochida. It can runs on serial or parallel but when I run "blockMesh" or "reconstructPar" or whatever utility different to the solver I always receive the following warning:
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1175
dlopen error : /home/mmontero/OpenFOAM/mmontero-2.1.1/platforms/linux64Gcc45DPOpt/lib/libmyIncompressibleRASModel.so: undefined symbol: _ZN4Foam14incompressible8RASModel11printCoeffsEv
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
could not load "libmyIncompressibleRASModel.so"
I think that the problem is located and it is because there are 4 new parameters and 2 new volScalarFields (canopyDensity and canopyLeaf) but RASModel.C/H does not recognize them.
.H
            const volScalarField canopyDensity_;
            const volScalarField canopyLeaf_;
.C
    canopyDensity_
        IOobject
            "canopyDensity",
            runTime_.timeName(),
            mesh_,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        mesh_
    canopyLeaf_
        IOobject
            "canopyLeaf",
            mesh_,
        mesh_
I hope someone could help me to clean this warning. The solver and the new turbulent model runs, converges and the results looks valid but...
Thank you very much
Marcelino
Lieven May 23, 2013 10:49
Hi Marcelino,
Do you load the library in the controlDict-file of the case?
Cheers,
L
be_inspired May 23, 2013 10:58
Yes, it is included.
The point is that the new turbulent model and the new solver are working correctly. I have compared the results with experimental data and looks "valid" ( it is quite difficult to know how is the density leaf of pines).
The warning only happens when using reconstructPart, paraFoam, blockMesh.... but no error or warning when performing the simulation.
I have looked for the same error in the forum and there is an old post about it but it seems that never was solved.
