May 25, 2013, 23:15 |
Runge-Kutta method for incompressible fluid
reza
Rep Power: 13 |
Hello All
I'm trying to implement an explicit Runge-Kutta 4 method to an incompressible fluid inside a 2-D cavity. I have already modified icoFoam.C but it does not work. could anybody advise me how to do it or refer me to a suitable tutorial? my modified icoFoam gives out the following error: [Make/linux64GccDPOpt/myicoFoam.o] Error 1 modified icoFoam.C int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; volVectorField H("H", U); H = -fvc::div(phi, U)+fvc::laplacian(nu, U); surfaceScalarField phitilta ( "phitilta", (fvc::interpolate(H) & mesh.Sf()) ); adjustPhi(phitilta, U, p); fvScalarMatrix pEqn ( fvc::laplacian(p) == fvc::div(phitilta) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); #include "continuityErrs.H" volVectorField k1("k1", U); k1 = runTime.deltaT()*[-fvc::div(phi, U)-fvc::grad(p)+fvc::laplacian(nu, U)]; volVectorField k2("k2", U); k2 = runTime.deltaT()*[-fvc::div(phi, U+0.5*k1)-fvc::grad(p)+fvc::laplacian(nu, U+0.5*k1)]; volVectorField k3("k3", U); k3 = runTime.deltaT()*[-fvc::div(phi, U+0.5*k2)-fvc::grad(p)+fvc::laplacian(nu, U+0.5*k2)]; volVectorField k4("k4", U); k4 = runTime.deltaT()*[-fvc::div(phi, U+k3)-fvc::grad(p)+fvc::laplacian(nu, U+k3)]; U = U+(k1+2.0*k2+2.0*k3+k4)/6.0; U.correctBoundaryConditions(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } Last edited by haghgoo_reza; May 26, 2013 at 01:29. |
May 30, 2013, 18:28 |
Thomas Boucheres
Rep Power: 12 |
many misunderstanding I think. First, your equation on the laplacian(p) cannot work since you use fvc namespace which is the namespace for explicit discretisation. For building a matrix as in a implicit scheme, you need to use fvm namespace. Second, and much more drastic, your algorithm for solving NS cannot work. Recall that incompressible NS system is constraint by div(u)=0 and this constraint is reflected at numerical level by the fact that one cannot use just a "consistant" algorithm to solve equation. Well defined predictor/corrector is the simplest scheme that can work. Roughly speaking, 3 phases: a- solve equation on U (with/without p) b- solve laplacian on p c- correct U The order and the phase 3 is fundamental. Note also that since you are working with collocated shceme (velocity and pressure are defined both at the cell centers), you need a well defined stabilisation on the velocity flux field (so-called Rhie-Chow stabilisation). I think you should review your algorithm before of all. Good luck. |
Main advantage of using Runge Kutta of higher order? | jakubstary | Main CFD Forum | 14 | August 20, 2019 16:15 |
Runge Kutta 4th Order Source Code | sugu | Main CFD Forum | 4 | October 26, 2012 03:15 |
1D Burgers euqation with 4th Runge Kutta | dokeun | Main CFD Forum | 3 | August 8, 2011 06:34 |
Level Set Method and Ghost Fluid Method | alvin11 | Main CFD Forum | 0 | October 24, 2010 09:46 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
