-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Study of the EEqn.H in rhoPimpleDyMFoam. (http://www.cfd-online.com/Forums/openfoam-programming-development/118406-study-eeqn-h-rhopimpledymfoam.html)
Horacio Aguerre May 27, 2013 08:03
I'm working with the solver "rhoPimpleDyMFoam" from the OpenFOAM 2-2-x version. In specific i was trying to replicate the polytropic process in an adiabatic compression.
The case i studied is a pistone-cylinder sistem where air is compressed by the pistone patch which is a moving wall. The pistone velocity is adjusted to 0,1(m/s) to aproximate a reversible process.
When i choose energy "he" as internal energy i could reproduce the polytropic process in an adiabatic compression.
However when i choose energy "he" as entalphy I couldn't achieve the theoretical expression pV^{1,4}=constant for air. Instead the system looks as it would be non adiabatic or like the conversion between work and internal energy was not made properly.
Therefore i started to study the EEqn.H.
I compare the theoretical balance of total energy in terms of entalphy with what is written in the EEqn.H.
Balance of a tensorial property in an arbritary moving domain.
\dfrac{d}{dt} \int_{V}\rho \phi dV + \int_{S}\rho \phi\left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}=-\int_{S}\rho \mathbf{Q_{\phi}} \cdot \mathbf{ds}+\int_{V}S_{\phi}dV
Balance of mechanical energy.
\phi \equiv \frac{\mathbf{v} \cdot \mathbf{v}}{2} = K
\dfrac{d}{dt} \int_{V}\rho K dV + \int_{S}\rho K \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds} =-\int_{S}\left(p\mathbf{v}+ \boldsymbol{\tau} \cdot \mathbf{v}\right) \cdot \mathbf{ds} + \int_{V} \left[p \left(\boldsymbol{\nabla} \cdot \mathbf{v}\right)+\boldsymbol{\tau}:\boldsymbol{\nabla v}\right] dV+ \int_{V}\rho\left(\mathbf{v} \cdot \mathbf{g}\right) dV
Balance of internal energy.
\phi \equiv \widehat{u}
\dfrac{d}{dt} \int_{V}\rho \widehat{u} dV + \int_{S}\rho \widehat{u} \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}=-\int_{S} \mathbf{q} \cdot \mathbf{ds}-\int_{V} \left[p \left(\boldsymbol{\nabla} \cdot \mathbf{v}\right)+\boldsymbol{\tau}:\boldsymbol{\nabla v}\right] dV
The balance of internal energy can be expressed in terms of entalphy.
\widehat{h}=\widehat{u}+\frac{p}{\rho}\implies \widehat{u}=\widehat{h}-\frac{p}{\rho}
Replacing in the balance of internal energy.
\dfrac{d}{dt} \int_{V}\rho \left(\widehat{h}-\frac{p}{\rho}\right) dV + \int_{S}\rho \left(\widehat{h}-\frac{p}{\rho}\right) \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}=-\int_{S} \mathbf{q} \cdot \mathbf{ds}-\int_{V} \left[p \left(\boldsymbol{\nabla} \cdot \mathbf{v}\right)+\boldsymbol{\tau}:\boldsymbol{\nabla v}\right] dV
\dfrac{d}{dt} \int_{V}\rho \widehat{h} dV+ \int_{S}\rho \widehat{h} \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}-\dfrac{d}{dt} \int_{V}p dV - \int_{S} p \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}=-\int_{S} \mathbf{q} \cdot \mathbf{ds}-\int_{V} \left[p \left(\boldsymbol{\nabla} \cdot \mathbf{v}\right)+\boldsymbol{\tau}:\boldsymbol{\nabla v}\right] dV
Balance of total energy.
The sum of the balances of mechanical and internal energy results in the balance of total energy.
\dfrac{d}{dt} \int_{V}\rho \left(\widehat{h}+ K \right) dV + \int_{S}\rho \left(\widehat{h}+ K\right) \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds} -\dfrac{d}{dt} \int_{V}p dV - \int_{S} p \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds}=-\int_{S} \mathbf{q} \cdot \mathbf{ds}-\int_{S}\left(p\mathbf{v}+ \boldsymbol{\tau} \cdot \mathbf{v}\right) \cdot \mathbf{ds} + \int_{V}\rho\left(\mathbf{v} \cdot \mathbf{g}\right) dV
If the terms of work of viscous forces and the gravity are neglected, the balance is:
\dfrac{d}{dt} \int_{V}\rho \left(\widehat{h}+ K \right) dV + \int_{S}\rho \left(\widehat{h}+ K\right) \left(\mathbf{v}-\mathbf{v_{b}}\right) \cdot \mathbf{ds} -\dfrac{d}{dt} \int_{V}p dV + \int_{S} p \mathbf{v_{b}} \cdot \mathbf{ds}=
rhoPimpleDyMFoam: EEqn.H
The balance of total energy in the EEqn.H file with he considered as entalphy \widehat{h} is:
fvm::ddt(rho, he) + fvm::div(phi, he) + fvc::ddt(rho, K) + fvc::div(phi, K)
- dpdt - fvm::laplacian(turbulence ->alphaEff(), he) == fvOptions(rho, he)
Where, \phi=\rho_{f} \left(\mathbf{v}-\mathbf{v_{b}}\right)_{f} \cdot \mathbf{S_{f}}, is relative to the mesh.
If fvOptions(rho, he) are considered as zero, the term \int_{S} p \mathbf{v_{b}} \cdot \mathbf{ds} from the final balance is no considered in EEqn.H.
Then i try adding in the EEqn.H the therm \int_{S} p \mathbf{v_{b}} \cdot \mathbf{ds}.
- dpdt + fvc::div(fvc::meshPhi(U),p) - fvm::laplacian(turbulence ->alphaEff(), he) == fvOptions(rho, he)
The result was correct. As in the first case (he=internal energy) the adiabatic compression was reproduced with the relation pV^{1,4}=constant.
The question is,
should the term \int_{S} p \mathbf{v_{b}}  \cdot \mathbf{ds} be introduced in any way in fvOptions(rho, he) or it must be explicit in the EEqn.H?
Thanks,
Horacio
santiagomarquezd June 12, 2013 22:15
Any clues?. It seems we have to upload the question to the bug tracker.
Regards.
santiagomarquezd July 8, 2013 18:43
http://www.openfoam.org/mantisbt/view.php?id=909
ALU August 20, 2013 08:33
1 Attachment(s)
I'm trying to simulate exactly the same case, but I get very unphysical solutions even using the internal energy formulation. I also tried your proposal concerning the EEqn.H file without any success.
You said you were able to reproduce the adiabatic compression, so I would appreciate it if you had a look at my settings or if you shared me your case.
Horacio Aguerre September 4, 2013 12:37
rhoPimpleDyMFoam: Adiabatic expansion
1 Attachment(s)
Originally Posted by ALU (Post 446886)
Hi ALU,
I tried your case without modifying it and i get bad results too.
I made the following modifications,
File: /0$ U
If you want to reproduce an expansion, you should set for the "top" velocity the same velocity of the "patch", in this case, 0.1 m/s for the third coordinate.
Remember that the type "fixedValue" indicates absolute velocities. If you want to set relative to domain velocities you can use type "movingWallVelocity".
File: /system$ fvSolution
I added in the subdictionary PIMPLE the flag "correctPhi" equal to "no".
The correctPhi equation makes the linear solver to diverge.
For compressible fluids, i think that this equation is no necessary as the non conservative effects due to the mesh change in the flux are absorbed by the density equation.
I run the case with a time step of 0.001s from time 0 to time 1s and the adiabatic expansion was obtained successfully.
The modification of the EEqn.H is necessary when you set, in the dictionary "thermophysicalProperties" (in thermoType{}), the energy to sensibleEnthalpy, but we have here sensibleInternalEnergy.
I hope this can help you,
Regards,
Horacio
ALU September 5, 2013 02:20
Hi Horacio Aguerre,
thank you very much for the correction of my case and the detailed explanation, this really helps a lot!
Regards
zqlhzx September 11, 2013 00:32
Hi ,Horacio Aguerre
could you see my problem and tell some thing?I think you can answer my question.I moves fireFoam of 2.0.1 to 2.2.1,then rewrite hEqn according to the EEqn.H in fireFoam of 2.2.1 and other necessary codes.But ,when I wmake my rewrited fireFoam,it gives me errors:undefine div(phi,h) in fvscheme.
The following is codes of EEqn.H:
volScalarField& he = thermo.he();
fvScalarMatrix EEqn
he.name() == "e"
? fvc::div
fvc::absolute(phi/fvc::interpolate(rho), U),
p,
"div(phiv,p)"
: -DpDt
- fvm::laplacian(turbulence->alphaEff(), he)
fvOptions(rho, he)
EEqn.relax();
fvOptions.constrain(EEqn);
EEqn.solve();
fvOptions.correct(he);
thermo.correct();
Info<< "T min/max = " << min(T).value() << ", " << max(T).value() << endl;
There is div(phi,he) insteading of div(phi,h),So It should be no need to define (phi,h) in fvshceme,but define div(phi,he).However,I see the fvsheme in smallpoolfire2D of 2.2.1,there indeed is div(phi,h).In fact,there is the term of "div(phi,he)" in EEqn.H,why define div(phi,h) in fvsheme?I think I have some thing not understand.!
http://www.cfd-online.com/Forums/ima...ser_online.gif http://www.cfd-online.com/Forums/ima...reputation.gif http://www.cfd-online.com/Forums/ima...ons/report.gif http://www.cfd-online.com/Forums/ima...c/progress.gif
Horacio Aguerre September 11, 2013 09:11
Energy variables
Originally Posted by zqlhzx (Post 451054)
Hi ,Horacio Aguerre
fvScalarMatrix EEqn
he.name() == "e"
? fvc::div
p,
"div(phiv,p)"
: -DpDt
fvOptions(rho, he)
EEqn.relax();
EEqn.solve();
thermo.correct();
Hi zqlhzx,
The EEqn is able to solve the energy balance in terms of enthalpy ("h") or internal energy ("e"). Both balances have common expresions. For this expresions it is used the generic energy variable "he". However the expresions differ. Then appears the conditional statement that selects the appropiate source term for the respective form of energy.
he.name() == "e"
Then "he" is like as a generic energy that is used in the definition of the EEqn, but in fact it is "h" or "e".
In fvSchemes and in fvSolution you must set for the energy parameters the name "he.name()"
If you choose enthalpy "he.name()=h" you must define "div(phi,h)" in fvSchemes.
If you choose internal energy "he.name()=e" you must define "div(phi,e)" in fvSchemes.
In the OpenFOAM official web site there is an explanation on how to set up the thermophysical properties.
HTML Code:
http://www.openfoam.org/docs/user/thermophysical.php
Regards,
Horacio
zqlhzx September 12, 2013 04:05
Thanks ,Horacio Aguerre!It is kind of you!
zqlhzx September 13, 2013 09:34
Dear Horacio Aguerre:
Thank you for your last reply!I have another problem I would like to consult you.In my thermophysicalPropertise,I want to define thermo type like this:
thermoType
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
energy absoluteEnthalpy;
equationOfState perfectGas;
specie specie;
}I want use "absoluteEnthalpy;",but when I run my case,it tells me have no this thermo combination.I found just "psiuReactionThermo" Class can use absoluteEnthalpy. "psiReactionThermo"and "rhoReactionThermo"can not use absoluteEnthalpy.They only have sensibleEnthalpy.My case have chemical reaction and I must use absoluteEnthalpy,can you give me advise how to change my thermo type?Thanks again!
santiagomarquezd October 11, 2013 13:43
Henry changed the code using the snippet suggested by Horacio, but in pEqn.H
https://github.com/OpenFOAM/OpenFOAM...d6c6406b07d7bb
Regards.
