volVectorField
Old   June 3, 2013, 23:36
Default volVectorField
reza
haghgoo_reza is on a distinguished road
Hello all,
I am trying to define a vector in openFoam with the following equation:
A = -fvc::div(phi, U)+fvc::laplacian(nu, U)
do you think I can use the following command to define my vector i.e. A.
volVectorField A("A", U);
A = -fvc::div(phi, U)+fvc::laplacian(nu, U);
I can not understand the meaning of A("A", U) in volVectorField A("A", U);
can anybody help me?
Thanks
haghgoo_reza is offline   Reply With Quote
Old   June 4, 2013, 05:29
Cyp
Cyprien
Cyp is on a distinguished road
means that your are creating a new volVectorField object declared as A. This object has to be constructed with a name, a dimension, a mesh.... Among the different constructors available, you can construct A from a name, and another volVectorField (U in this example). The main problem in your snippet is that with such a declaration, A should have the same dimensions as U. But it's wrong... I think the following code is better :
volVectorField A("A", -fvc::div(phi, U)+fvc::laplacian(nu, U));
Best,
Cyp
Cyp is offline   Reply With Quote
[Problem] paraFoam Throws volVectorField Error At t=0 for 0/U iamed18 OpenFOAM Pre-Processing 3 April 11, 2016 10:03
subtract volvectorfield and dimensionedvector ggoggodak85 OpenFOAM Programming & Development 1 January 28, 2014 14:54
Pstream reduce sum volVectorField ganeshv OpenFOAM Running, Solving & CFD 0 December 11, 2012 14:35
dot product of volvectorfield latvietis OpenFOAM 1 November 20, 2012 02:16
Initialize a uniform 0 volVectorField Schag OpenFOAM 3 August 26, 2009 10:08
