Home > Forums > OpenFOAM Programming & Development
Convection Term
Old   June 4, 2013, 10:25
Default Convection Term
anton_lias is on a distinguished road
Hello Foamers,
I have modified the solver MRFInterFoam to solve the population balance equation via the Quadratic method of Moments.
Now I would like to add the convection term (see attached file)
m is a scalarField
c1 and c2 are constants (scalars)
First I tried this Equation, but I understand, that I can't calculate "scalar - tensor".
fvScalarMatrix mEqn
    U & fvc::grad(m)
    - fvc::grad(c1 * fvc::grad(m1)
    +c2
So I tried this Equation (found in a paper) and add c2 later on.
fvScalarMatrix mEqn
	fvm::div(phi, m)
	- fvm::laplacian(c1, m)
Does this Equation computes the Equation given in the attachment?
Thanks for your help.
anton_lias is offline   Reply With Quote
Old   June 5, 2013, 18:49
Thomas Boucheres
thomasArk47 is on a distinguished road
yes it is better. Don't forget to add the temporal derivative and the source term. Look at applications/solvers/basic/scalarTransportFoam.
thomasArk47 is offline   Reply With Quote
Old   June 6, 2013, 10:05
Thank you Thomas.
Do you mean something like that?
solve
        fvm::ddt(m)
        + fvm::div(phi, m)
        +c2
Old   June 6, 2013, 16:52
Thomas Boucheres
Ok for the time derivative.
For the source term, it is not good. Ok, I assume your "c2" is a fixed variable. This way, you have 2 possibility:
1- use
solve
fvm::ddt(m)
+ fvm::div(phi, m)
fvm::Su(c2f,m)
...where c2f can be declared after the m variable as follows:
DimensionedField<scalar,volMesh> c2f
IOobject
"c2f",
m.time().timeName(),
m.mesh(),
IOobject::NO_READ,
IOobject::NO_WRITE
m.mesh(),
dimensionedScalar("c2f",m.dimensions()/dimTime,c2)
2- cleaner approach by using the fvOptions framework. Needs to write:
solve
fvm::ddt(m)
+ fvm::div(phi, m)
fvOptions(m)
In this approach, you need to define in the right way the fvOptions file located in the system file. Look at the tutorials to find the syntax you need.
N.B : if c2 is not a fixed variable, the first approach is probably the simpler for first try (you could use the second one in combinaison of the codedFunctionObject)
Old   June 18, 2013, 08:02
Thank you thomas its working
Thread Tools
Trackbacks are On
PISO algorithm for particular NS equation (special convection term) Cyp OpenFOAM Programming & Development 8 June 12, 2012 09:36
[Q] Convection term treatment in UDS Ryan, Lee FLUENT 4 October 18, 2004 10:20
Convection Term Discretization Maciej Matyka Main CFD Forum 3 October 7, 2004 04:32
Convection term with moving grids nicolas FLUENT 0 December 10, 2003 08:34
Additional Convection Term Richard Phoenics 4 March 19, 2001 04:10
