BC which interpolate from an existing solution
Dear foamer,
I try to create a boundary condition which interpolate the volumic velocity field of an existing case (sourceCase) to the inlet patch of a running case (runCase). To do this, I use the interpolate static method include in surfaceInterpolation.H. Here is a piece of code included in the "updateCoeff" member function of my boundary: Code:
fileName sourceRootDir = "path/to/source"; Code:
--> FOAM FATAL IO ERROR: Code:
interpolationSchemes |
Dear Marcel,
I have the same problem, did you find a solution? Kind Regards Anne |
I fixed the error "interpolate(U)" by just adding one line in the IOobject of meshSource Code:
fvMesh meshSource In the meantime, I used a different approach, but let me know if you have a working boundary! Cheers, Marcel |
