programming & icoFoam
Like Tree1Likes
  • 1 Post By sharonyue
Old   June 9, 2013, 06:02
Default programming & icoFoam
Sasan Ghomi
sasanghomi is on a distinguished road
Hi foamers ,
what is the relation between non-orthogonality in the grid and number of solving P.Equ ???
please take a look at this part of icoFoam :
PHP Code:
for (int nonOrth=0nonOrth<=nNonOrthCorrnonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rUAp) == fvc::div(phi)
pEqn.setReference(pRefCellpRefValue);
pEqn.solve();
                if (
nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
why the number of solving P.Equ should be equal nNonOrthogonalCorrectors ??
I think in PISO algorithm the number of solving pressure equation should be equal nCorrectors. I think nNonOrthogonalCorrectors is related to quality of grid generation.
what is the relation between grid's quality and number of solving pressure equation??
Can anyone clarify this issue for me ?
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   June 9, 2013, 15:27
Retired Super Moderator
Bruno Santos
Hi Sasan,
Does this answer your questions: http://openfoamwiki.net/index.php/IcoFoam ?
Best regards,
Bruno
Old   June 9, 2013, 16:51
Sasan Ghomi
Hi Bruno,
Thanks for your reply.
I want to know that why the quantity of solving pressure equation is equal to quantity of nNonOrthogonalCorrectors ?
Sasan.
Old   June 9, 2013, 17:33
Bruno Santos
Hi Sasan,
I'm not sure I understand you correctly... are you asking about the following code?
if (nonOrth == nNonOrthCorr)
    phi -= pEqn.flux();
edit: or is it about:
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
Best regards,
Bruno
Old   June 10, 2013, 02:31
Sasan Ghomi
Hi Bruno,
I am asking about :
Sasan.
Old   June 10, 2013, 07:24
Bruno Santos
Hi Sasan,
Well, as the wiki page explains:
Originally Posted by http://openfoamwiki.net/index.php/IcoFoam
// iteratively correct for non-orthogonality. The non-orthogonal part of the Laplacian is calculated from the most recent
// solution for pressure, using a deferred-correction approach.
Any explanation beyond this (that I could find) is on this thesis:
... which I don't have time to read and study .
Best regards,
Bruno
Old   August 25, 2013, 23:55
Dongyue Li
sharonyue is on a distinguished road
Hi ,
http://www.cfd-online.com/Forums/ope...tml#post447985
I think this will make it clear.
It is related to quality of grid generation and the non-orthogonal correction in the diffusion term, you can dig it in page.83 of Jasak's thesis.
wyldckat likes this.
sharonyue is offline   Reply With Quote
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
Programming in OpenFOAM vinu OpenFOAM 2 July 11, 2009 10:16
IcoFoam Not Installed and blockMesh command not found cesarbz OpenFOAM Installation 6 July 4, 2008 04:44
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
