November 19, 2013, 10:34 |
Add Local Time Stepping (LTS) to Solver
L.Bryce Whitson Jr.
Rep Power: 14 |
I have been looking through the code for the local time stepping algorithm and it looks like the setrDeltat.h and setInitialrDeltat.h files could be added to any solver to implement local time stepping versus global time stepping. Is this true or am I missing something?
For example, look at rhoPorousMRFPimpleFoam vs rhoPorousMRFLTSPimpleFoam. The only real difference in these two are those two files. The same is true for reactingParcelFoam and LTSReactingParcelFoam as far as I can tell. Thoughts? |
November 21, 2013, 08:34 |
Aurelien Thinat
Rep Power: 15 |
Hi LWhitson,
I was wondering quite the same thing considering the solver twoPhaseEulerFoam which can take days for some cases. Did you get any answer elsewhere ? |
November 28, 2013, 07:19 |
Rep Power: 13 |
the implementation of LTS is really that easy.
but the solution are only accurate for steady state solutions. |
local time stepping, openfoam 2.x |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
