RegionCoupling - openfoam 1.6ext
2 Attachment(s)
Dear All
Im trying to solve my previous case which was based on chtmultiregionfoam with conjucateheatfoam. my boundary at the interface of solid and fluid looks like: -K1grad(T1)=Ksgrad(Ts)+sigma I dont use coorectboundarycondition for K . so I dont have harmonic interpolation of K. and for T I am doing the interpolation similar to energyRegionCoupledFvPatchScalarField in openfoam 2.2 Code:
Field<Type> fOwn = this->patchInternalField(); which sigma is just defined on surface of the interface. in the correct result I should get some sort of generation due to sigma and the internal field should be effected by that. the boundary values that I get after modifying regioncoupling is the same as the values at the boundary that I get by chtmultiregion :D. but its not puting any effect on the internal field !!!!!:confused::(. I would appreciate any comment best mahdi |
please give me some idea
Hello Dr. Mahdi,
Have you found any solution for adding a refGradient value so we satisfy the harmonic mean in the interface? I am working on a similar case with Suzan model plasma. Thank you! |
