Adding LTSInterfoam to foam-extend 3.1
Old   June 16, 2015, 11:57
Default Adding LTSInterfoam to foam-extend 3.1
despodan
Daneish is on a distinguished road
Send a message via Skype™ to Daneish
Good day,
To start off, i would like to let you know I have OpenFOAM 2.3.1 and foam-extend 3.1 in my computer. I installed foam-extend because i wanted to use swak4foam and had difficulties installing it in OpenFOAM 2.3.1.
Now i want to do some simulation using LTSInterFoam in foam-extend 3.1 but is not there.I can run it of2.3.1 but i want to use swak4foam to do some calculations so thats why I would like to know how add it to foam-extend 3.1 . I tried copying it from of2.3.1 and then compiling it but this led to some erros show in the image below.
I hope someone can help.
Many thanks,
Daneish
Daneish is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
