Home > Forums > OpenFOAM Programming & Development
prefcell&prefvalue meaning
Old   June 22, 2013, 08:42
Default prefcell&prefvalue meaning
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Hi everyone,
what do the following lines do in createFields?
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
thanks in advance
AmirBaqa1987 is offline   Reply With Quote
Old   June 22, 2013, 11:58
Nima Samkhaniani
nimasam is on a distinguished road
Dear Behnoud
solvers need the value of pressure at least in one point, so this line consider the value of the pressure of pRefCell equals zero
Training Course on OpenFOAM at (http://www.isme.ir/)
My Weblog (http://openfoam.blogfa.com/)
nimasam is offline   Reply With Quote
Old   June 22, 2013, 12:01
Fumiya Nozaki
fumiya is on a distinguished road
If you don't fix the pressure values on any boundaries for the incompressible flow,
the pressure values can not be determined. In this case you need to specify
the pressure value(pRefValue) at the cell(label: pRefCell).
Hope that helps,
Fumiya
fumiya is offline   Reply With Quote
Old   July 31, 2013, 12:27
Default pRefvalue
musaddeque hossein
musahossein is on a distinguished road
Dear all:
The default pref is set to a high number 1e5 as shown below in the fvsolutions file (sloshingTank2D):
pRefPoint (0 0 0.15);
pRefValue 1e5;
Is this a standard or can it be set to zero? If it can be, how would I set it so that it is absolute zero (like in fortran absolute zero is set as 0.0d0).
I look forward to your reply.
musahossein is offline   Reply With Quote
Old   July 31, 2013, 13:25
Nima Samkhaniani
you can use zero! for incompressible case, but for compressible case you should assign absolute pressure
Old   July 31, 2013, 14:14
Default pRefvalue
musaddeque hossein
thanks for your response! I have another question. I need to probe a point for pressure. I do not want to a probe in controlDict since that would mean that I would have to run the solver each time I need to change the probe location, for example. I would therefore like to have the probe in the sampleDict file. I have the following code in my sampleDict file. But each time I run sample, OpenFoam ignores it. Any suggestions will be greatly appreciated. Thanks!
functions
probes1
type probes;
functionObjectLibs ("libsampling.so");
region region1;
probeLocations
(0 0.5 -0.3)
fields (p);
Thread Tools
Trackbacks are On
Meaning of Ychar and Ypmma aylalisa OpenFOAM Pre-Processing 2 October 20, 2013 05:49
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 08:04
what is the meaning of patching shyam FLUENT 1 July 29, 2008 06:25
want to know meaning Sangamesh CD-adapco 0 May 15, 2007 05:15
What's the meaning of "combustion scalar"and.... cfdbeginner CFX 0 November 27, 2003 10:02
