Home > Forums > OpenFOAM Programming & Development
interFoam symbol lookup error
Like Tree1Likes
  • 1 Post By sharonyue
Old   June 24, 2013, 05:24
Default interFoam symbol lookup error
Dongyue Li
sharonyue is on a distinguished road
I am a newbie to linux.so its a mass when I compile my solver.
I changed the code in "twoPhaseMixture", and rename it "myTwoPhaseMixture" and this is the code in make/file:
myTwoPhaseMixture.C
LIB = $(FOAM_USER_LIBBIN)/libincompressibleTransportModels
Then I wamke libso, succeed.
In interFoam, I revise it like this, and name it as myinterFoam, except this nothing changed:
#include "/home/cfd/myCase/mylib/twoPhaseMixture/myTwoPhaseMixture.H"
and wmake successful.
But when I run myinterFoam, it said:
myinterFoam: symbol lookup error: /home/cfd/OpenFOAM/cfd-2.2.0/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so: undefined symbol: _ZTIN4Foam14transportModelE
Anyone knows how to handle this?
Thanks
sharonyue is offline   Reply With Quote
Old   June 24, 2013, 06:55
Nima Samkhaniani
nimasam is on a distinguished road
Dear foresst
in Make folder, in Options files, you should add
-L$(FOAM_USER_LIBBIN) \
-lincompressibleTransportModel
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   June 24, 2013, 08:21
Dongyue Li
Originally Posted by nimasam View Post
Dear foresst
Hi Nima,
It works, but there are some other problems: In order to find out whether its incurred by my code, I make a test:
(1) copy twoPhaseMixture.C and twoPhaseMixture.H to my folder
(2) wmake libso
(3) copy interFoam too my folder
(4) wmake.
But it said "undefined reference", This time I didnot touch any code, so I dont know whats wrong with this. I attach my code, If you have time, could you please help me to check it out? I believe its easy for you. Thanks.
Old   June 24, 2013, 08:41
Nima Samkhaniani
i can not unextract your zip file
Old   June 25, 2013, 21:24
Dongyue Li
I think I compile the lib successfully, but problem arises in compiling the solver.
this is my option:
EXE_INC = \
    -I$(LIB_SRC)/transportModels \
    -I $home/cfd/myCase/mylib/incompressibleTwoPhaseMixture/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude
EXE_LIBS = \
    -linterfaceProperties \
    -ltwoPhaseInterfaceProperties \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    -lmeshTools \
    -lfvOptions \
    -lsampling \
    -lincompressibleTransportModels
when I wmake, it said:
cfd@cfd:~/myCase/solvers/interFoam$ wmake
options:22:27: warning: backslash and newline separated by space [enabled by default]
SOURCE=interFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I. -I/opt/openfoam220/src/transportModels -I ome/cfd/myCase/mylib/incompressibleTwoPhaseMixture/incompressible/lnInclude -I/opt/openfoam220/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam220/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/fvOptions/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/interFoam.o
interFoam.C:44:29: fatal error: twoPhaseMixture.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/interFoam.o] Error 1
But this file is in that folder.
mecman likes this.
Old   June 26, 2013, 01:01
Nima Samkhaniani
twoPhaseMixture.H: No such file or directory compilation terminated.
did you include it properly in right path?
Old   July 11, 2013, 03:27
Default fatal error
Mohammad Bahreini
mecman is on a distinguished road
Hi Forrest
i have problem same youre problem....do You solve this problem?if you solve,can you help me?
my error:
interFoamDiabatic.C:44:29: fatal error: twoPhaseMixture.H: No such file or directory
make: *** [Make/linux64GccDPOpt/interFoamDiabatic.o] Error 1
mecman is offline   Reply With Quote
Old   July 11, 2013, 06:34
Nima Samkhaniani
Dear mohamad
when you use an include file! you should tell the compiler where to find it
Old   September 17, 2013, 05:31
Dongyue Li
Dear mohamad
Sorry, I still cant wmake it.
I "wmake libso" my twophasemixture.c , then in interFoam, I change it into this:
EXE_INC = \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -lfvOptions \
    -lsampling  \
    -lmyincompressibleTransportModel
but it said: cannot find -lmyincompressibleTransportModel
but I have a myincompressibleTransportModels.so in my FOAM_USER_LIBBIN folder.
Sorry, my fault, it should be -lmyincompressibleTransportModels
Thread Tools
Trackbacks are On
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
